Trans Temp too high? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-15-2013, 09:16 PM Thread Starter
NVHunter83's Avatar
I have an 08 CCLB F-350 with a 5" Flo pro and a Mini Maxx with the Easy tune loaded currently. Yesterday I drove up a 15% grade for 3-4 miles of very whindy road at 20-25mph. The air temp was mid to high 80s. Elevation was 3500 up to 5200 feet during the climb.
Question is, my trans got up to 218 and my oil temp was 222 while my coolant was 213. I was unloaded pretty much, maybe 300-400 lbs of gear in the bed. Are those numbers too high for a pull like that? The road is steep, and all three temps dropped back down to normal ranges within 5 minutes.
Just wondering.
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #2 of 4 Old 07-16-2013, 05:50 AM
srjd's Avatar
Quoted: 2 Post(s)
I wouldn't worry a out it. A lot of things come into play that effect temp. Mine climbed to 225 on about the same hill one day and all other stays was much lower. I thought my trans was going and it was winter and cold no snow on the road. The next time I hit that hill I was able to go faster and the TC locked and temps were much cooler. Especially since all your temps came back down shortly after I wouldn't worry about it just keep an eye on it
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 4 Old 07-16-2013, 07:06 AM
muntu's Avatar
those temps are low....bet your fan never even came on. towing up hill on a hot day you'll see coolant and oil go over 230*....fan set to come on tranny 220* oil 225*.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #4 of 4 Old 07-16-2013, 09:26 AM Thread Starter
NVHunter83's Avatar
Ok thanks guys, not sure what's extreme and what's not regarding pulling grades and towing.
Thanks
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
