Transmission acting up maybe?? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-15-2013, 04:37 PM Thread Starter
Ok Got some questions for you guys
I noticed going into second gear it would shift hard into it.
Then I started smelling something like a burning transmission a couple days later.
Then I checked my transmission fluid. It is full but there is debris on the measuring stick that looks like big brown sand. Im pretty sure this is really bad.
I still havent figured out what the burning clutch/transmission/brakes/ radiator fluid smell is coming from.
Just got the truck a little bit ago. Do I need to flush? Do I need a new filter? (I know nothing about transmissions.)
2008 f250 6.4 61,000 miles.
cor21e is offline
post #2 of 10 Old 07-15-2013, 05:06 PM
The trans should be flushed at around 50k miles so it sounds like you are due.
Tjmaxx is offline
post #3 of 10 Old 07-15-2013, 05:09 PM Thread Starter
I heard transmission flushing is a joke and you really don't get all the debris out unless you drop the pan and there is a filter and a magnet that you need to replace/clean?? Is this true?
cor21e is offline
post #4 of 10 Old 07-15-2013, 07:34 PM
floorboy's Avatar
That is the preferred way to do it.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #5 of 10 Old 07-15-2013, 07:34 PM
srjd's Avatar
Quoted: 2 Post(s)
I just drop what's in the pan I think that get about 1/3 of it. And I do that about once a year. If your has that much junk in it could be time for a flush. I've heard flushes can screw it up tho. Hopfully someone else chimes in
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 10 Old 07-15-2013, 07:37 PM
srjd's Avatar
Quoted: 2 Post(s)
Nevermind I see somone beat me to it
srjd is offline
post #7 of 10 Old 07-16-2013, 06:14 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ this. I would drop the pan and put a new filter. I also believe there was a TSB about rust in the transmission dipstick tube. I don't remember the TSB number tho.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 10 Old 07-16-2013, 08:14 AM Thread Starter
Took it in to my local shop. And they said there are rusty granular substance in it. waiting to hear back
What is a TSB????
cor21e is offline
post #9 of 10 Old 07-16-2013, 08:39 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
its fairly common. Check out this thread. Oh and a TSB is a technical service bulletin.
Gunk on trans dipstick??? Pics
08 F350 cc/sb 4X4
post #10 of 10 Old 07-16-2013, 08:10 PM Thread Starter
Thanks for the replies. Cant find the tsb??????
Took it to the shop and had them drop the tranny pan. Replaced the filter and all fluid.
Absolutely spotless transmission.
Thanks Ford for being an idiot. Why would you put a dipstick tube in it that would make people think they had rust in their transmission.
just wasted $350......
cor21e is offline
