Building the ultimate tow rig - Ford Powerstroke Diesel Forum
post #1 of 45 Old 07-15-2013, 05:31 AM Thread Starter
CNYWhiteDually's Avatar
Just picked up the truck a month ago
it is a 2008 f350 6.4l diesel with a manual trans (zf6)
4x4 dually, i plan on doing all the deletes and full custom 5" exhaust
i will be posting all of the mods and processes along the way.
here is a pick of the stock truck
CNYWhiteDually is offline
post #2 of 45 Old 07-15-2013, 07:50 PM
WesGee's Avatar
I like it. Are you going to be towing competitively or as a toy hauler?
Sent from AutoGuide.com App
WesGee is offline
post #3 of 45 Old 07-16-2013, 04:37 PM
XPLOSIV's Avatar
Will be following along. Have plans of my own, but might steal a few of your ideas.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #4 of 45 Old 07-16-2013, 05:04 PM
44magnum's Avatar
Quoted: 2 Post(s)
Builds are always welcome.
I'm curious as well, what will you be towing?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #5 of 45 Old 07-18-2013, 06:26 AM Thread Starter
will be towing anything that i come across, race cars, gooseneck with tractors, maybe a dozer or two just the normal heavy loads. should be an anwesome build
post #6 of 45 Old 07-24-2013, 06:03 AM Thread Starter
Quick Update, i just got my spartan tuner ordered up should be here by the end of the week, got to get the manual specific tunes for it. Also im in the works of building and making a fully custom 5" exhaust for the truck. upon doing some shopping i was seeing colant filter kits go for $170 and this is just crazy, i can make my own kit for around 70 maybe or less??? i will post the part numbers of the filter and filter block im using.
post #7 of 45 Old 07-24-2013, 08:59 AM Thread Starter
worked on exhaust designs today, should be buying tube in the next week
post #8 of 45 Old 07-24-2013, 09:00 AM Thread Starter
here are some examples
ID:	144377   Click image for larger version
post #9 of 45 Old 07-24-2013, 11:28 AM Thread Starter
just ordered my colant filter and filter base, check my post on the performace board for the 6.4l Here it is re-posted.
Dont pay for the overpriced kits for a anodized piece of aluminum and some hose, save your money and spend it on better upgrades. Im here to share the wealth, i did some reasarch and here you go,
Go to your local hardware store and buy all the hose and clamps for this install, roughly
10 ft hose
8 hose clamps
2 tee fittings
2 valves to mount to block ( not nessicary but when you change the filter you can close the valves and not loose much or any colant)
Order these from NAPA
Filter adapter base
part number# FIL 4763
$49.99
NAPA AUTO PARTS
Colant Filter
part number# FIL 4070
$15.49
NAPA AUTO PARTS
Or if you wanted to use it for an aditional fuel filter
Filter part number# FIL 3225
Either way this is way less expensive then the kits and will help save your money for better mods and longevity of your engine.
post #10 of 45 Old 08-06-2013, 04:55 AM Thread Starter
just picked up my coolant filter and block this weekend, also got my mudflaps installed. I custom cut a set of Big rig international flaps to fit. They were only $10.99 apiece so well worth it.
