EMPTY degas bottle? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-14-2013, 09:06 PM Thread Starter
fishprowler's Avatar
EMPTY degas bottle?
I have only had my 08 about 2 months. I have been away and my truck has not been run in about 5 days. I have to leave early in the morning for about a 900km round trip. I just got home today and went out to check my oil before the drive tomorrow (habit) and noticed my degas bottle is completely empty?? I have never noticed a single drop of coolant on the ground anywhere. Temps have never been high either.
Is this terrible? And can I top up with water?? Nothing will be open yet when I have to leave in the morning.
2008 F-350 Lariat CCLB 6.4
Spartan on 310 tune
S&B Intake
FloPro 5" straight pipe
Rudy's EGR Delete
Black Widow Alarm w/ Remote Start
2.5" ReadyLift
20x9 Fuel Hostage
35x12.5x20 Nitto Trail Grapplers
Westin Bull Bar
fishprowler is offline
post #2 of 9 Old 07-14-2013, 09:14 PM Thread Starter
I should clarify that there was actually about an inch in the degas bottle. Any my truck is stock.
Spartan on 310 tune
S&B Intake
Rudy's EGR Delete
2.5" ReadyLift
20x9 Fuel Hostage
Westin Bull Bar
post #3 of 9 Old 07-14-2013, 09:28 PM
matted2thefloor's Avatar
If you didn't see any external leaks...assuming you checked the radiator area and hoses thoroughly, and the degas bottle was that low, there's only one other place for it to go. I wouldn't top it with water unless it is distilled water. Best bet is to top it with coolant...the same type coolant that is already in there.
Good luck!
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #4 of 9 Old 07-14-2013, 10:19 PM Thread Starter
Well I added 3 liters of distilled water to get it back to the cold fill line. Ran around for about 20 mins to get it up to temp. Checked again and it had dropped about 1/2" from where it was cold. I'll se how it is after my trip tomorrow.
I didn't check all the hoses throughly because I figured 3 liters was something bigger than a tiny leak, that I've seen no trace of on the ground?
Spartan on 310 tune
S&B Intake
Rudy's EGR Delete
2.5" ReadyLift
20x9 Fuel Hostage
Westin Bull Bar
post #5 of 9 Old 07-15-2013, 07:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Is there white smoke coming out of the exhaust? Sounds like maybe a ruptured egr cooler?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 9 Old 07-15-2013, 08:12 AM
Eric@PTP's Avatar
Look for residue on the Drivers side frame rail inside the fender before the tire, also look at the radiator on the drivers side to.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #7 of 9 Old 07-15-2013, 09:03 PM
Had you previously done any work involving the cooling system? Could have been an air pocket that cleared. Otherwise...I have to agree with either the EGR cooler failure or HG.
post #8 of 9 Old 07-15-2013, 09:35 PM Thread Starter
Just got home from my trip and it ran like a champ. No white smoke at all. Drove nearly 1000km today (600+ miles) with zero issues and it doesn't look like the coolant has gone down at all from where I filled it to yesterday. It's dark now but tomorrow I'll get under and have a good look for residue on the frame rail. Any obvious things to look for for HG?
Spartan on 310 tune
S&B Intake
Rudy's EGR Delete
2.5" ReadyLift
20x9 Fuel Hostage
Westin Bull Bar
post #9 of 9 Old 07-18-2013, 08:48 AM
Timing Cover Cavitation.
Another 'Where is my coolant question?'
S1nned is offline
