delets in an emissions controlled state - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-13-2013, 01:18 PM Thread Starter
Vodka0tter's Avatar
I live in MA that has a strict emissions testing. I decided to do a DPF pipe delete along with EGR blocking plates. While today I simply bolted the delete pipe in and clamped it to my muffler I plan on flanging both delete pipe and DPF pipe assy back at the muffler for easy swapping. Should be an easy swap out when sticker time rolls around.
I decided to install block off plates on the EGR and kinda jacked that up. Top plate went in no issues, the bottom plate gave me problems. I ended up jacking up the gasket cause it would only separate such a small amount. screwed up the gasket stuffing something in to separate the pipes. Now it leaks a bit - need to fix that.
But I am wondering if there is a real advantage to putting plates in. I mean the EGR is shut off with the H&S tune. Easy enough to put the DPF pipe in, flash the PCM with no delete and the EGR is fine for emissions. So the question is what is the advantages of putting plates in v/s just shutting it off via the H&S tuner. I wanna keep everything intact for inspection and the plates make it a PIA.
BTW - I still cant believe the gains with these simple mods and tune. Fricking diesels rock!
Vodka0tter is offline
post #2 of 4 Old 07-13-2013, 07:45 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Benefit of block off plates over just shutting the valve:
1. The valve is on the top of the motor so the exhaust gases still travel thru both EGR cooler and add unnecessary heat to your coolant.
2. The block off plates keep heat in your exhaust and not running up your engine (ie heating up your coolant and intake air, even if just a little because the valve and intake elbow are hot).
It is still a bandaid because coolant is still running thru but if you have no ability to remove then completely the plates are better than nothing.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 4 Old 07-24-2013, 03:20 PM
Send a message via Yahoo to skipnay
Can he make them stay there put make them so they don't heat up the coolant and other stuff? I don't know much on the EGR and have been thinking about getting rid of mine also but they need it for a visual.
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #4 of 4 Old 07-25-2013, 05:15 AM Thread Starter
Vodka0tter's Avatar
I used block off plates. The go under the EGR and just before the cooler intake keeping averything in tact and not looking like anything has changed. Pretty simple to put in however I succeeded in destroying the gasket on the cooler end. Mine was kinda hard seperating the cooler from the pipe. I actually pulled the plates back out, replaced the gasket and called it a day. Just didnt want to have one more thing to play with when came time for inspection...
