Coolant? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-12-2013, 05:12 PM Thread Starter
Coolant?
Anyone run anything other than Ford coolant? Changing my hoses and stats and wondering if i can pickup something at AZ or another parts store that will work fine it would be a bit more convienent?
Stroke4Fun is offline
post #2 of 13 Old 07-12-2013, 05:52 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd go to a cat dealership and pick up some CAT ELC… really anything ELC is better than that crap Ford gold stuff.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 13 Old 07-12-2013, 06:19 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Lots of threads on this.
Napa carries Zerex. Oreilly's has Peak Final Charge, which is what I use.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 13 Old 07-12-2013, 06:40 PM Thread Starter
There is a Napa close i guess Zerex it is! How many Gal's do the 6.4's need? Got to stop tomorrow and get a crap load of distilled water for the flush!
post #5 of 13 Old 07-12-2013, 06:53 PM
29 L. Sorry, I'm Canadian. 31 quarts
Hauser is offline
post #6 of 13 Old 07-12-2013, 06:54 PM
jesilvas's Avatar
Quoted: 2 Post(s)
NAPA AUTO PARTS
That is the PN you want. Concentrate coolant.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 13 Old 07-12-2013, 06:56 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Total coolant capacity in the 6.4 is just a touch under 33 qts...YES...over 8 gallons. All but two quarts is for the main cooling system with those two quarts going in the fuel cooler.
So that means since you want a 50/50 mix, you need to add 4gals of concentrate to after your final distilled water drain.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 13 Old 07-12-2013, 07:19 PM Thread Starter
Ok that works! Is there a coolant filter on the 6.4?
post #9 of 13 Old 07-12-2013, 07:31 PM
Echo's Avatar
Not from the factory.
Echo is offline
post #10 of 13 Old 07-12-2013, 07:36 PM Thread Starter
I didn't think so but i thought i seen someone mention one must have been a Sinister!
Thanks for the info. guys!
