Mini max wiring?? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-11-2013, 06:34 PM Thread Starter
floorboy's Avatar
Mini max wiring??
Which wire do I hook my mm to so that it comes on with the key? Thanks. I don't want to try to search off my phone.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #2 of 8 Old 07-11-2013, 07:08 PM
ATVJOE's Avatar
If I remember correctly there is a purple wire within the wire bundle under drivers side dash (2008).
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #3 of 8 Old 07-11-2013, 07:41 PM
I've wondered the same thing!
Tjmaxx is offline
post #4 of 8 Old 07-11-2013, 09:08 PM
Quoted: 48 Post(s)
correct, solid purple wire in the PTO bundle
on the 6.7 trucks it's a white wire w/ blue stripe
drunk on diesel is offline
post #5 of 8 Old 07-12-2013, 01:08 AM
Where does the purple wire plug into the unit?
Tjmaxx is offline
post #6 of 8 Old 07-12-2013, 03:34 AM
diesel212's Avatar
Doesn't plug into unit you have to tap into it
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
20" Rockstars on 33's
diesel212 is offline
post #7 of 8 Old 07-12-2013, 04:18 AM
Vodka0tter's Avatar
I just put my MM in. I saw the purple wire (well one anyway) but it was hot, even with no key in. Must have been the wrong one but any way I just found one off the column that stayed hot with the key on and not when off.
Vodka0tter is offline
post #8 of 8 Old 07-12-2013, 07:14 PM Thread Starter
floorboy's Avatar
Ok thanks. I'll check into it.
floorboy is offline
