Wiring LED backup lights...? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-10-2013, 03:37 PM Thread Starter
NVHunter83's Avatar
I've searched and I can't find a definitive answer. I have 2 15 watt LED auxiliary work lights that I want to wire into the reverse lights of the truck. What would be the best way to wire these lights up?
I've found the yellow capped wire coming from the trailer wire harness but I don't have a clue how I should wire these up. Should I use a relay? If I use a relay can I also add a switch to have the lights function while in reveres and have the choice of turning them on when I want.
If I use the yellow wire, what terminal on a basic relay would it tie into....
Just seeing if anyone can give me a little direction on how they did theirs maybe.
Thanks
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #2 of 3 Old 07-11-2013, 05:56 AM
live for the now
ZombieSoldier's Avatar
this should help you a little....
TikiWiki : Smart Auxiliary Back Up Lights
2008 F250 6.4 - a little of this, a dash of that and soon you have made a truck the way Ford should have made it!
ZombieSoldier is offline
post #3 of 3 Old 07-11-2013, 03:56 PM
wired1's Avatar
I wired my up to the trailer reverse light wire. I will be putting a diod in so I can use the an up fitter switch to turn then on when I want as well and not back feed the system.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
