Here we go again with another coolant question - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-09-2013, 06:25 PM Thread Starter
I have read many opinion threads regarding coolant flushing; it's OK to drain and refill with Ford Gold; you must flush with VC-9 before refilling with the Gold; you must flush with VC-9 before filling with CAT-1; it's Ok to drain and refill with an ELC without flushing with VC-9, etc., etc. I have the Ford Gold now and my delta is 2*. I definitely don't want to replace an oil cooler any time soon. I already have the new Ford Premium Gold on hand. I was intending to drain the old, flush with distilled water and refill with the Gold, but the more I read , the more uncertain I am. Can anyone offer a definitive reason to support a drain and fill with Gold or replacing the Gold with an ELC without flushing with VC-9?
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 5 Old 07-09-2013, 08:53 PM
srjd's Avatar
Quoted: 2 Post(s)
The gold coolant is an excellent coolant when monitored properly. I'm sticking with the gold. My deltas are 4-6 I have a coolant filter and change the 1-2 times a year just a simple drain and refill. It's the guys that don't monitor it that have oil cooler issues.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 5 Old 07-09-2013, 09:18 PM
superduty6.4's Avatar
I agree with SRJD that the ford gold is fine if you maintain it properly. Personally I just didnt want the hassle of checking nitrates but as long as you are willing to stay on top of the maintenance of the gold then you will be fine. When I did my flush, I did not use and of the chemicals. I just use tap water for the first few flushes and distilled for the last few. It worked fine for me.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #4 of 5 Old 07-10-2013, 06:40 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I agree that ford gold is ok as long as it is properly maintained. I went with the cat elc for the longer service intervals. Anytime you do a chemical flush you are risking clogging your oil cooler depending on how dirty your system is. You can just flush with distilled water and refill.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 5 Old 07-11-2013, 06:44 PM Thread Starter
Went to the Ford dealer in the next town and had the cooling system vacuumed out and machine flushed twice with distilled water and filled with new Gold. I furnished the Gold and the distilled water and they did it for $85. The old Gold looked pretty good, no gunk. Degas bottle is clean. I'm going to order some test strips and check what I've got now and at every oil change. Delta is still 2*.
wargle is offline
