Smoke - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-09-2013, 05:03 PM Thread Starter
Smoke
How much smoke are you guys putting down if you are deleted and say, economy tuned? I have the DPF-R4.0. I get enough black smoke on normal acceleration to see it in the outside mirror and maybe twice as much on WOT acceleration. I know deleting the DPF will cause some smoke, but I don't know how much to expect. I still have my EGR. Thanks.
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 4 Old 07-09-2013, 05:16 PM
Both my EGR and DPF are deleted and I run a edge race tuner on level 2 and mine smokes pretty much exactly as you described maybe a little more when I get on it.
not to thread jack you but did you notice a difference in your mpgs with your tonneau cover was looking at buying one and wanted to hear from someone who actually has one first TIA
thnderchcken is offline
post #3 of 4 Old 07-09-2013, 06:05 PM Thread Starter
Couldn't tell about the mpg. Truck had an A&E fiberglass cover on it when I bought it. Couldn't pull my 5th wheel with it, so I sold it and got the Lo-Pro. Really a nice cover. Stays dry and you can use your entire bed if needed.
wargle is offline
post #4 of 4 Old 07-10-2013, 03:09 PM
WesGee's Avatar
I have a cover on mine, wasn't enough of a difference to notice if there even was one.
Sent from AutoGuide.com App
WesGee is offline
