Are short trips bad for my truck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-09-2013, 04:49 PM Thread Starter
rubicon53's Avatar
So I just got a new job that is only 5 minutes from my house is that going to be bad on my 6.4 I have a tuner and delete if that makes any difference
rubicon53 is offline
post #2 of 5 Old 07-09-2013, 08:00 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
With it deleted it definitely helps because u don't have to worry about making it all the way through a regen if it were to happen on the way to work. My truck is stop and go short rides all day long usually. And we haven't had any issues with our trucks really. You should be fine. Just be sure to take it out and open it up once a week or so
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 5 Old 07-09-2013, 08:48 PM
srjd's Avatar
Quoted: 2 Post(s)
Longer trips are always better, but the industry I working in I see 6.4s idle all day and make 100 meter trips and they are still running. Being deleted helps a lot!
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 5 Old 07-10-2013, 07:54 AM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
And don't romp on it if your engine temp isn't in the normal operating temp range. Short trip like that your probably barely getting the engine to normal temp
flashover1969 is offline
post #5 of 5 Old 07-10-2013, 08:56 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
you'll definitely want to run it longer at least once a week, or use marine grade oil in the thing.... at that time/distance, h20 that condenses in the crank case doesn't have enough heat long enough to vaporize out..
drewactual is offline
