Deltas while towing? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-08-2013, 04:52 PM Thread Starter
montana6.0's Avatar
Just wondering what everyone is seeing on this and how much the delta factor comes into play? I was seeing 10 or so
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #2 of 16 Old 07-08-2013, 06:35 PM
superduty6.4's Avatar
I see 6-10 degrees as well.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 16 Old 07-08-2013, 07:06 PM
cbenn's Avatar
Quoted: 3 Post(s)
I pull around 15,000#s and normaly see no more than 5/6 degrees difference.
2017 F350 Lariat Dually
Airlift air bags W/ Wireless remote.
2.5 Icon coil springs
PMF adjustable track-bar
PMF dual steering stabilizer
cbenn is offline
post #4 of 16 Old 07-08-2013, 07:14 PM
Mexigeo's Avatar
Around 10 degrees here too
Sent from AutoGuide.com App
2009 F350 SC FX4 6.4 Powerstroke
Originally Posted by Big Angry Hillbilly View Post
I hear that Dodge gives you a puppy with every truck you buy, so you'll never have to walk home alone again.
Mexigeo is offline
post #5 of 16 Old 07-08-2013, 07:49 PM
floorboy's Avatar
5-6 towing about #8000.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #6 of 16 Old 07-08-2013, 07:58 PM Thread Starter
montana6.0's Avatar
Ok well hopefully I don't have problems then with the oil cooler.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
post #7 of 16 Old 07-08-2013, 08:18 PM
What is your delta unloaded?
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #8 of 16 Old 07-08-2013, 08:54 PM Thread Starter
montana6.0's Avatar
Usually 6 depending on speed I did 1k mile trip and it averaged 8 doing 80 pretty much whole way and around 80* out for temp
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
post #9 of 16 Old 07-08-2013, 09:28 PM
kevinah's Avatar
4-6 towing 5-6000lbs at 55-70. I've seen as high as 7 difference pulling long grades at slower speeds in 4 wheel drive.
kevinah is offline
post #10 of 16 Old 07-09-2013, 04:47 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
montana: clean your exchanges..... make sure you have as unobstructed a flow as you can through those things..... you'll likely see your deltas drop afterward.
drewactual is offline
