Ccv mod sucks - Ford Powerstroke Diesel Forum
post #1 of 32 Old 07-03-2013, 10:15 PM Thread Starter
floorboy's Avatar
Ccv mod sucks
Ok so I put on my No-Limit intake a couple weeks ago. I did the ccv mod at the same time as the intake doesn't have a port for it. When the conditions are right I have a what would appear to be a cloud coming from under my truck. ( not much actually comes out of it, but it looks like it.) there has to be a better system.
Would it work to run it through a small cooler (like an aux trans cooler) to condense the smoke (or vapor) coming out of the hose and run it the through some sort of a catch can and then out to the back of the truck or back into the intake better yet??? The cooler would have to be oriented so that it drains out I imagine.
As it stands now I hate it. I can't imagine what it is gonna look like next winter when it gets cold.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #2 of 32 Old 07-03-2013, 10:28 PM
Deererainman's Avatar
Ditto. I seem to terrorize innocent people beside me at stop lights. I've heard of some people welding a nipple onto their muffler and running it out the exhaust. Theory is smoke will be out the exhaust and the flow will pull / vent the vapor better.
Deererainman is offline
post #3 of 32 Old 07-04-2013, 07:03 AM Thread Starter
floorboy's Avatar
Yeah, I've heard some very mixed reviews of that. There has to be a way of making it work.
floorboy is offline
post #4 of 32 Old 07-05-2013, 07:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Darkhorse diesel makes a kit that runs into the exhaust. I think the key is installing it at a 45* angle.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 32 Old 07-05-2013, 07:28 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Why don't u run a hose back to the rear of your truck instead of just leaving it in the engine bay. Put a small filter in the end if you want or check out those other closed kit systems. Just make it end at the rear of your truck
Big_Smokey is offline
post #6 of 32 Old 07-05-2013, 07:29 AM
Term3's Avatar
A bud did this but downstream from his muffler. Stainless steel 1" tubing at a 45 degree angle with the end also cut at a 45 degree angle. Just make damn sure there isn't any dips in the hose going to the tubing that can collect liquid. He's had his for about three years now with zero issues.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #7 of 32 Old 07-05-2013, 07:33 AM
ThomasvillePavers's Avatar
There is a thread for the older trucks here and aside from the design he used being much to large and bulky IMO the same concept works with a metal type filter element. I have seen lots of different styles and people even using the small crankcase filters you can buy off the shelf but the metal style filter element (even steel wool) seems to really eliminate the smoke AND odor the best.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #8 of 32 Old 07-05-2013, 08:15 AM
h1gg1n5's Avatar
I will say that I smell mine here and there. and also terrorize people at stop lights as well but everytime I smell it I think "better to smell it than be going back into the motor".
Also mine is vented through a 12' hose down in the middle of my box.
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #9 of 32 Old 07-06-2013, 09:51 PM
TD-5's Avatar
Quoted: 3 Post(s)
https://www.mann-hummel.com/industri...BVFLGOcGNM.pdf
I am using one of these,the pro vent 200. They utilize a coalescing filter to remove the oil mist from the crankcase vapor. can be run in closed or open configuration.
The oil drain from the filter can be run back to the oil pan in two different configerations or it can simply be run to a catch can & drained as needed. Due to the limited amount of usable space with the 6.4 crammed in the engine bay. I mounted mine out front & used a catch can. I am initially running it as an open system with the outlet hose run back to the air intake filter. If I find this isn't working out I will run it back to the stock location on the inlet as a closed system. I've only got a couple 1000 k on the system , but everthing looks good so far. In the winter, Condensation & or freezing of any water vapor may be a problem with where I have mine located, but time will tell.
Name:	pro vent 1.jpg
ID:	135306   Click image for larger version
Name:	pro vent 3.jpg
ID:	135314   Click image for larger version
Name:	pro vent supply hose from engine.jpg
ID:	135322   Click image for larger version
Name:	provent  discharge hose to air intake.jpg
ID:	135330   Click image for larger version
Name:	pro vent drain to catch can.jpg
TD-5 is offline
post #10 of 32 Old 07-06-2013, 10:02 PM
superduty6.4's Avatar
I ran mine across the top of the motor, down by the area where the EGR coolers were, and left the open end just behind my front bumper. I haven't been able to smell it even a little bit yet. I also don't see any smoke at all. I think the fan slowly spinning takes all the smoke and smell away. I also just did a long tow with my travel trailer and looked underneath where it vents. There was a fair bit of smoke underneath but standing in front of the truck I couldn't smell or see anything.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
Tags
ccv
