Am I going to pass? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-01-2013, 08:40 PM Thread Starter
Am I going to pass?
I have a 2008 6.4 with mini maxx off road tune and a dpf delete straight pipe. I just got the letter in the mail for emissions testing. I have the factory egr in place so I'm hoping to pass? It does not have any lights on indicating an issue. But I will have to unplug my tuner for them to test for emissions. Here in Wisconsin I can take it to my ford dealer to get checked I don't know if this will help at all? My wife is going to murder me if this thing fails I may be trading in on the spot lol.
Tjmaxx is offline
post #2 of 26 Old 07-02-2013, 01:54 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I don't think I would take it to ford. It would have to be a smaller guy that you could give him a $20 to pass you. But idk they may pass you without the extra money. Hopefully someone chimes in from around your area that has experience with a deleted truck
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 26 Old 07-02-2013, 02:34 AM
usnavyad's Avatar
Feedback Score: 3 reviews
The tune isn't that back reset to stock for emissions the dpf delete on the other hand you may have a problem
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #4 of 26 Old 07-02-2013, 04:03 AM Thread Starter
There are a lot of 6.4's running around my area but haven't had a chance to talk to any of them. I know I've seen plenty with tuners and exhaust may not be deleted
Tjmaxx is offline
post #5 of 26 Old 07-02-2013, 05:37 AM
Quoted: 2 Post(s)
if its anything like it is here in VA, diesels don't get emissions tests. its more of a formality. you're prob going to be ok. they may just hook it up to the computer, make sure there are no emissions codes, and you're good to go. hopefully someone will chime in from your area.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #6 of 26 Old 07-02-2013, 10:39 AM
Usually the emissions test is a SNAP test. They quickly floor the accelerator to see the amount of smoke generated. They know that the 2008 and newer trucks shouldnt smoke, or smoke very, very little. I worked at an Ohio emissions station for years. Now depending on your states emission requirements, you may be able to get a waiver if your vehicles GVRW is above a certain number. In Ohio I have an EPA waiver and as long as I dont lose it, I am not required to test.
jimb726 is offline
post #7 of 26 Old 07-02-2013, 07:27 PM
I just went thru this in Milwaukee. If they hook up to your OBD port, you will fail the EGR "readiness" portion of the test.
The MMax cycles the EGR on the Easy Tunes, but blocks the system from setting the EGR system to "ready".
I had load the stock OEM tune and re-install DPF to pass.
Sucks!
Mike
2010 F250 CCSB Lariat FX4
MikeSherman is offline
post #8 of 26 Old 07-02-2013, 07:41 PM
Here in CO, I set the tuner back to stock and switched the oem exhaust/Dpf out. You can try to pass but without the Dpf, you should fail the visual test. All emission places are different, best thing to do is either find someone in your area with experience or just wing it the first time. Even if you fail, it should be free to go back at least once, that way you'll know for sure what had to be done.
rdwngs444 is offline
post #9 of 26 Old 07-02-2013, 07:42 PM Thread Starter
Sucks!
Mike
Sounds like I'm going to fail
Tjmaxx is offline
post #10 of 26 Old 07-02-2013, 07:52 PM Thread Starter
Has anyone tried returning to stock tune but leaving the dpf off? Maybe stop in the parking lot and return to stock tune then leave and return back to offroad tune?
Tjmaxx is offline
