DPF-R+4.0 - Ford Powerstroke Diesel Forum
post #1 of 28 Old 06-28-2013, 07:03 PM Thread Starter
DPF-R+4.0
Any of you guys running the DPF-R+4.0 have any issues with transmission shifting after installation? I am under the impression that the DPF-R is not supposed to make any changes to the transmission shifting. I just installed mine and it seems like the shifts are much closer together and I seem to have a shift flare in 2nd and 3rd in more than light acceleration. If I put in in tow/haul it seems to shift more like it did before the DPF-R.
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 28 Old 06-29-2013, 06:51 AM
What year truck and what job # do you have? I have a Job 1 08 and it does the exact same thing. Runs fine with light acceleration but when you give it gas it revs up between 2nd and 3rd and sometimes between 3rd and 4th. I called gearbox and said they have never heard of this and that it might be a transmission problem. I am running DPF delete only with factory flash and it runs fine. Its something to do with the 4.0 flash.
bsparks is offline
post #3 of 28 Old 06-29-2013, 06:59 AM Thread Starter
I have a 2010. Don't know the job number, maybe job 2. In service date was Feb. 7, 2010. Could this problem be damaging the transmission?
wargle is offline
post #4 of 28 Old 06-29-2013, 07:16 AM
I cant answer that, and thats why i flashed it back to stock w/dpf delete. I dont know much about transmissions, but it seems that it could be causing the clutches to slip and that cant be good. Its not normal, so im not risking it with a $4000 trans. Hopefully someone with transmission knowledge will chime in.
I think the programmer and the TCM just arent working together, or something else thats electrical.
bsparks is offline
post #5 of 28 Old 07-03-2013, 06:34 PM
FlintRidgeFarmSN's Avatar
Strange to hear someone with a later model truck having this problem. I have a Job 1 08 that will occasionally flare up with light throttle and shift hard between 2nd and 3rd or 3rd and 4th. I called the company that i got my tune from (River City Diesel) and they said that all 08 Job 1 trucks do the same thing when tuned. Which didnt really help me to much but i was relieved to know it wasnt necessarily just my transmission being weird.
08 F250 Crew Cab SB 4wd
-SCT Livewire with RCD 450 Tune
-Diamond Eye DPF/CAT Delete
-4" MBRP DPF Back with 5" Tip
-Sinister EGR Delete
-35" Nitto Trail Grapplers
At some places they play football...at Alabama we live it.
FlintRidgeFarmSN is offline
post #6 of 28 Old 07-03-2013, 07:27 PM Thread Starter
I returned the truck to stock then re-flashed without the economy tune and the shifting seems to be normal again. I did not get a chance to hand check the mileage while the economy tune was in place, but the lie-o-meter was showing 22mpg, up from about 16 before, so there should be an increase of 2-3 mpg. in real life. Anyway, there is something wrong with the programming in the DPF-R economy tune. I have emailed Gear Box Z about the problem, but they have not replied.
wargle is offline
post #7 of 28 Old 07-08-2013, 07:03 AM
69Stang's Avatar
I've been looking at getting one of these. Did they ever get back with you?
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #8 of 28 Old 07-08-2013, 07:06 AM Thread Starter
nope. I'll Try Again.
wargle is offline
post #9 of 28 Old 07-08-2013, 07:14 AM
69Stang's Avatar
Thanks. Doesn't give me a lot of confidence when they don't answer emails.
69Stang is offline
post #10 of 28 Old 07-08-2013, 08:03 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
there is a relationship between the engine and the transmission that you upset with the new tune- if you were to give it time and distance, the transmission would adapt to the engine tune... torque management won't allow you to put all the power to the terra unless you wipe it's previous adaptive memory (via trans tune), or, you give it time and distance... the trans tunes that come along with other tuners address the timing and pressure expectations at different RPM levels... your transmission simply didn't have a stored logic for what you were asking it to do.
drewactual is offline
