brake pedal leak - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-27-2013, 08:20 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
brake pedal leak
Had a drip on my floor mat looked under seems to be coming from a plastic piece attached to the cyclinder at the top of the brake pedal mount. Any ideas
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 11 Old 06-27-2013, 11:59 PM
Mikers's Avatar
Master cylinder
2008 F350 DRW Powerstroke
1993 Ford Bronco 5.8
1990 Ford F150 5.0
1955 Ford Customline
1993 Ford Escort RS Cosworth (Racer)
It exist only Ford and then comes the rest
Mikers is offline
post #3 of 11 Old 06-28-2013, 11:44 AM
It is the hydroboost....I had the same thing and got it replaced. It is a common problem. If you are under warranty, get it fixed, if not keep an eye on it and watch your fluid level. The hydroboost controls both your steering pump and brakes. If it fails, you're screwed. However, they do not fail often, they just leak.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 11 Old 06-28-2013, 05:11 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
It's not brake fluid leaking its more like hydraulic fluid. I did a quick search I guess others that had this issue said its to do with the mechanism that controls the power pedals. Ill just keep and eye on it. Could it be hydro boost or would it be brake fluid that's would be leaking then
srjd is offline
post #5 of 11 Old 06-28-2013, 07:08 PM
Echo's Avatar
If it is the hydro boost leaking it will be power steering fluid. Master cylinder will be brake fluid.
Echo is offline
post #6 of 11 Old 06-28-2013, 09:52 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I'm thinking its from the power pedals. The fluid is not power steering or brake fluid.
srjd is offline
post #7 of 11 Old 06-28-2013, 10:11 PM
Echo's Avatar
The adjustable pedals move by an electric motor. No fluid involved. Your leak is coming from something else.
Echo is offline
post #8 of 11 Old 06-28-2013, 10:20 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Ill have to look it up again there was a long thread about it on another site with a TSB.
srjd is offline
post #9 of 11 Old 06-28-2013, 10:25 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Something about the lithium grease from brake pedal melting on hot days if the seal is bad it will drip. It does look like grease that's been heated up. It's forsure not brake or steering fluid. Either way its odd. My power steering fluid I change lots it gets burnt very quickly
srjd is offline
post #10 of 11 Old 06-29-2013, 08:02 PM
I got same issue. Only happened once and it felt like grease. Only did it onceon very hot day.
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
