6.4 HPFP Failure No Warranty - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-26-2013, 04:37 PM Thread Starter
Long story short my 6.4's fuel was contaminated with dirt, probably from pumping fuel at a gas station somewhere. My fuel filters and oil are changed at frequent intervals. A couple dealerships want $9,000 to replace every component in the fuel system. It's not Ford's fault, it's not my fault, its a gas stations fault, as I was told. I think an engineering failure exists as under normal operating conditions and fuel pumping the truck self destructed in 1,500 miles. Insurance also will not cover this.
Frequent Ford advertisements depict Ford trucks as being badass work machines. But I cant even pump fuel into my Ferd F-Teen Thousand and get it down the road.
I'm going to clean the tank out myself, replace the filters, and try to blowout/clean every component I can.
If the problem persists, at the least I will have to replace the HPFP assembly and pull the engine through the front end. I bought a superpremium warranty for several thousand dollars and I feel that it is useless as I was charged $250 for diagnostics and my truck is parked. I AM NOT A SATISFIED CUSTOMER.
I most certainly feel shafted by Ford, and rest assured if I have to pull the Powerstroke engine out, a mechanical Cummins is going in.
BigBlockFox is offline
post #2 of 18 Old 06-26-2013, 07:44 PM
kevinah's Avatar
Insurance could possibly cover
kevinah is offline
post #3 of 18 Old 06-27-2013, 08:23 AM Thread Starter
Called up the insurance company. If I wanted to file a claim they would send someone out to look at it for $$$ and most likely not cover it.
post #4 of 18 Old 06-27-2013, 08:43 AM
dieselflash's Avatar
We've had insurance pay for several trucks with contaminated fuel. If you had receipts for your fuel then the insurance company would go after the gas station.
Ford Master Diesel Tech
dieselflash is offline
post #5 of 18 Old 06-27-2013, 08:55 AM Thread Starter
There is no "the" gas station, I pumped diesel all across the country...
post #6 of 18 Old 06-27-2013, 10:43 AM
Quoted: 2 Post(s)
I save every fuel receipt, it doesn't matter if i pump 5 gallons, or 25 gallons into my trucks fuel tank. Just for this very reason. If i get some contaminated fuel, i'm going straight to the station that i filled up at. i have fuel receipts from 12 months ago. It's just something i do for piece of mind, and when the receipt wont print at the pump, i walk inside and have one printed no matter how much of a rush i am in. I hope you get this worked out. $9K is a boat load to fork out for a new fuel system.. let us know how it goes. best of luck.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #7 of 18 Old 06-27-2013, 10:51 AM Thread Starter
I bought the truck used, its only worth about 15k now. Its a single cab XL, So 9 grand to fix it seems ridiculous. Ill be more careful when pumping fuel now...
post #8 of 18 Old 06-27-2013, 12:07 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Something seems weird. First post says insurance won't cover it but then u says insurance hasn't looked at it because that would cost money. I would rather pay the insurance company the little $$ versus 9k for everything that's fuel related on the truck.
When u get it fixed, only buy diesel from stations that sell alot. Going to the little store at the end of the road with one diesel pump at the back of the lot isn't good because their diesel sits longer. Sitting longer means its got more chances for water to be in it and also dirt because they may not fill diesel up all the time so it could be pulling from. The bottom.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #9 of 18 Old 06-27-2013, 12:13 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
dang that sucks, i have never had this problem but how does the insurance pay for a fuel issues just for my infor
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #10 of 18 Old 06-27-2013, 12:16 PM Thread Starter
I contacted my insurance company, and was told that if I filed a claim they would send someone to come out and look at the truck for $$$. I was also told there was a very good chance the claim would be denied.
If I file the claim ill be out of pocket for the inspection and my rates will probably go up, as I was also told by the insurance spokesperson. The chances of insurance covering the repairs are slim to none, especially because I am not exactly sure where the bad gas was pumped.
Therefore the insurance company is out of the picture.
Tags
6.4 , contaminated , failure , fuel , hpfp
