Torque Converter Hiss - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-25-2013, 05:24 PM Thread Starter
reighnman's Avatar
I've been wondering what this is for a long time and today after driving around with the windows down got a bit annoyed. I just figured I'd ask in case it turns out to be something that eventually hurts the TC.
Basically I run H&S S2L which is 5th lockup only @ 45mph. When the TC locks, there is a loud swoosh or hissing noise similar to a boost depressurizing noise, though much slower. Hard to describe but if I'm just cruising around with minimal throttle (no boost) and the TC locks, as the RPMS dip there is a sppshhh noise. I can manipulate the sounds with throttle (like it's building pressure), say if I give it some throttle while it's pshhing I can carry it.
It could be coming from the turbos but it's really loud and sounds like it's coming from under the truck. It also doesn't stay in sync with boost pressure (gauge) so not sure. Doesn't sound like any of the typical turbo noise I hear outside of TC lock.
Black 2008 F250 Lariat 4x4 6.4L CC Job3, DPF/DOC Delete, H&S mini maxx, S&B Intake, vista-pro radiator
Black 2010 Mitsubishi Evolution, UR, AMS
reighnman is offline
post #2 of 6 Old 06-25-2013, 06:22 PM
WoodBoy's Avatar
Its turbo surge. Not going into details but your rpms is dropping a good bit while your intake valves, etc arent accepting air as fas as they was and the air has to go somewhere so it trys to force back out the turbo
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 6 Old 06-25-2013, 06:29 PM Thread Starter
reighnman's Avatar
nm guess I'll just ignore or switch to S2H
post #4 of 6 Old 06-25-2013, 07:28 PM
srjd's Avatar
Quoted: 2 Post(s)
if it is turbo surge then switching shift schedule or tunes wont matter just dont floor it and let off really quick.....unless thts not your problem then i have no idea
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 6 Old 06-25-2013, 07:51 PM Thread Starter
reighnman's Avatar
There is minimal if any boost when the TC locks, I'm talking going into TC Lock @ 1500-2000 rpm with minimal throttle pos.
post #6 of 6 Old 06-26-2013, 02:54 AM
tony97gt's Avatar
I asked the same question a few months ago but didn't get much help. It's not the turbo from what I can tell, I also believe it's the torque conv.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
