weather stripping - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-23-2013, 08:06 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
weather stripping
went to shut my rear driver door tonight and sounded like it was filled with water so i pulled the weather stripping off the bottom and there were two drain plugs. I pulled those and they were clogged with mud once I got the mud out of there bunch of water drained. well went to put the weather stripping back on and those plastic rivets that go in easy but break on the way out are toast and I need some new ones......Does any one know where I could pick some of those up?
Thanks
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 6 Old 06-24-2013, 01:44 AM
6.4ford's Avatar
Same here man. I'm going to check with my friend who works at a local dealer if he can get some
Sent from AutoGuide.com App
6.4ford is offline
post #3 of 6 Old 06-24-2013, 07:23 AM
08PowerstrokeFX4's Avatar
Should be able to get at the local dealer. Don't know part number off hand. You can also try a local parts store, they usually deal with a company like Au-Ve-Co that makes the body clips, panel fasteners, and the such. Might be worth a try instead of the dealership, should be a lot cheaper too!
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
post #4 of 6 Old 06-24-2013, 06:12 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
yeah i imagine the dealer would be an arm and a leg for some little plastic pieces. Thanks for the tip ill look this weekend and see what I can find
srjd is offline
post #5 of 6 Old 06-25-2013, 08:55 PM
Alberta Advantage's Avatar
Quoted: 20 Post(s)
I just bought a new driver's side weatherstrip/gasket for my truck as there was a crack/split down the middle of it by the windshield in the front door and it was just under $150 at Woodridge. Of course, it wasn't in stock and had to be shipped from Edmonton.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #6 of 6 Old 06-26-2013, 09:23 PM
Clayton1985's Avatar
Both my back doors bottom strips are long gone and the front doors the corners hang... The first winter I had truck up here they froze and stuck to cab and that was the end of em.....
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
