Drivers up-pipe question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-23-2013, 09:28 AM Thread Starter
fordmanmark1's Avatar
I searched this and can't get the answer I'm looking for. The question is, I'm pulling my turbos to rebuild and have to loosen up the drivers side up-pipe I do have a full EGR delete with a blocking plate at the bottom of the pipe. Is the sencer on that pipe active with my h&s egr delete? And if so would it be ok to just eliminate that pipe and put my blocking plate on the passenger up-pipe that pipe connects too?
2015 F-350 Platnum FX4 Superduty 4X4 6.7L crew cab Longbed 3.55's 5th wheel prep
Old truck's 95' 7.3 LB EXT 4X4 285,000 miles very much Missed! 08' F-250 6.4 fully deleted
Lots of mods to come
Quote:The right of the people to bear arms shall not be infringed.
fordmanmark1 is offline
post #2 of 8 Old 06-23-2013, 11:25 AM Thread Starter
Anyone ? I'm in a tight spot and need to know smoothing or a thought please!
post #3 of 8 Old 06-23-2013, 01:58 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
I just did this and I have a write up on it At well. Let me find it. Ebp sensor relocation
Big_Smokey is offline
post #4 of 8 Old 06-23-2013, 02:01 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
This is something I think everyone should do when doing egr delete. Here it is. Hope this helps. It's a tight squeeze with your arms. Good luck. Http://www.powerstroke.org/forum/6-4...elocation.html
post #5 of 8 Old 06-23-2013, 02:05 PM Thread Starter
Thanks Big Smokey, I'll check it out! Much appreciated here is a pic of the bad boys with cab on. Feels like I'm working at Roush again!Drivers up-pipe question-imageuploadedbyag-free1372025034.774542.jpg
post #6 of 8 Old 06-23-2013, 03:37 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
No prob. What's the deal with the turbos. Upgrade or a fixing issue
post #7 of 8 Old 06-23-2013, 04:14 PM Thread Starter
I started smoking at idle after warmed up, no loss of fluids just strong diesel smell goes away while driving. Went thee the motions and found some oil in the turbo. I run mild hot tune mostly and pull a 5er from time to time so I figured it was time for some new wheels to drop some EGT's . Had trouble with that dam driver up-pipe with the catalyst and just thought why the hell do I need that Dom thing with a delete?
post #8 of 8 Old 06-23-2013, 04:16 PM Thread Starter
Oh ya she has 140,000 on it now! Been full deleted with intake and exhaust since 102,000
