Quick EGR delete question. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-22-2013, 06:10 PM Thread Starter
I am in the process of installing one on my 08 and I am hung up on the upper bolt on the horizontal EGR cooler. It seems as though it is pretty much seized on there and am wondering if a propane torch would create enough heat to be able to back it off? This is hopefully the only thing keeping me from getting this job done.
Fussgus is offline
post #2 of 12 Old 06-22-2013, 07:05 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Knock er loose and dont round the edges off. U could try the heat.
Big_Smokey is offline
post #3 of 12 Old 06-22-2013, 07:05 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Have you tries WD-40's new rust penatrent? This stuff works great, I recently removed the exhaust manifolds from my 67 F100, first bolt I broke off then I went to the parts store and picked up a bottle of that stuff, applied it a few times waiting about 20 min inbetween coats and after about 4-5 times the nuts and studs came. I did use an impact gun though and I'm not sure if you can get one in there. I hope this helps you out, good luck.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 12 Old 06-22-2013, 08:23 PM Thread Starter
I don't think I could round the edges. a 10mm fits perfectly but there is just no leverage that can be applied in that horrible spot. I have not tried that new wd40, didn't even know they came out with one. I was thinking about getting some pb blaster but time was running out for the night.
Fussgus is offline
post #5 of 12 Old 06-22-2013, 08:32 PM
fordmanmark1's Avatar
Try some JB 80 it's like pb blaster but a bit thicker . I had trouble with mine also. Try heat just be very careful not to overheat. I don't think a propane torch will quite get it hot enough. Map gas might help if u can get some good torches it would be better. Remember patience goes a long way
2015 F-350 Platnum FX4 Superduty 4X4 6.7L crew cab Longbed 3.55's 5th wheel prep
Old truck's 95' 7.3 LB EXT 4X4 285,000 miles very much Missed! 08' F-250 6.4 fully deleted
Lots of mods to come
Quote:The right of the people to bear arms shall not be infringed.
fordmanmark1 is offline
post #6 of 12 Old 06-22-2013, 08:55 PM Thread Starter
I can get jb 80 at oreileys or napa or somewhere like it?
Fussgus is offline
post #7 of 12 Old 06-22-2013, 08:58 PM
I got mine at Car Quest, don't know if the other ones have it but u can look' its in a black can with a big 80 on the front
post #8 of 12 Old 06-23-2013, 01:37 PM
Quoted: 8 Post(s)
Did you get your bolt off? What did penetrant did you use?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 12 Old 06-23-2013, 02:29 PM Thread Starter
I used heat which I didn't really need I don't think. I had to take off the drivers side wheel well cover and that gave me enough room to pull with enough force to break it free. Odd thing is, my truck as of right now is no longer leaking like it was and may be leak free now. I will do some more driving to see if things stay this way.
Fussgus is offline
post #10 of 12 Old 06-23-2013, 02:54 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Yah sorry.i had the wheel well out also. I used the long egr delete write up off here as some assistance
