what is a 2008 6.4 worth with blowed turbo - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-21-2013, 02:40 PM Thread Starter
i have found a 2008 cc 4wd with a 6.4 with blowed turbo the truck is in perfect shap it only has 94000 miles on it what should i give for it
wadepowerstroke is offline
post #2 of 4 Old 06-21-2013, 05:32 PM
srjd's Avatar
Quoted: 2 Post(s)
way to little info. Why did the turbo blow could have just been faulty could have had extremely old sludge oil that caused it to seize in which case the motor could be in rough shape. Id walk away. If it was in perfect shape the turbo would be too
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 4 Old 06-22-2013, 12:03 AM
F450Harley's Avatar
You gotta have 25 grand of your own money to play this game.
A truck for sale with a blown turbo translates to a broke a$$ owner who cant fix it..............so offer him 10 grand.
You are gambling on it. Is it just the turbo that broke.........or turbo and blah blah......blah.....................blah?? That is the reason for your low offer.
If he s offended at your offer, throw the ball on his court. Ask him to fix it and you will buy it for 23. If not.........ask how come (get big eyes & a suspicious look) ??
Even though he knows it........dont be bashful to remind him kinda nicely that:
What s better for him? 10 grand now & a bad memory or looking at that thing wroughting away.
Title on hand like always
F450Harley is offline
post #4 of 4 Old 06-22-2013, 05:52 AM
Quoted: 2 Post(s)
Turbo not working right vs disintegrated turbo makes a HUGE difference. If the turbo is busted enough that the motor can't start and idle for at least a few seconds, then like 450 says, lowball at 10K because most likely parts of the turbo broke and went through the motor.
If the turbo grenaded, then the truck was running(and under load),and if the thing was running then the motor is F'd. Point is, don't let him buffalo you by saying it runs, but he doesn't want to start it and cause more damage.
If it runs with no funky noises, "might" be worth bumping up to 15k. Of course check oil for any coolant.
Fordnut74 is offline
