Help choosing steering stabilizer - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-20-2013, 08:15 PM Thread Starter
Quoted: 2 Post(s)
I currently have the stock stabilizer and dual pro comp stabilizers installed. The ProComp stabilizers are leaking and need replaced.
Should I ditch the dual pro comps and buy a Bilstein to replace the stock stabilizer?
Top Gun Customz makes a dual stabilizer kit with dual Bilsteins for $329. Seems like a nice set up
Anyone running either setup or know of a better set up?
Blue Turd is offline
post #2 of 5 Old 06-21-2013, 05:20 AM
Quoted: 2 Post(s)
i run the dual Bilsteins, with the stock stabilizer removed. nice set up and works good.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 5 Old 06-21-2013, 06:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
blue turd is your truck lifted or leveled?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 5 Old 06-21-2013, 02:32 PM Thread Starter
Quoted: 2 Post(s)
Do you have the same kit?
post #5 of 5 Old 06-21-2013, 02:33 PM Thread Starter
Quoted: 2 Post(s)
Guess I need to add a signature. It has a 6 inch lift with 35's
