Gas in fuel tank....... - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-20-2013, 08:05 AM Thread Starter
Red '97's Avatar
Exclamation Gas in fuel tank.......
So dad has a 2010 6.4, 100,000 miles. He accidentally put a little bit of gas in the fuel tank, no more than a couple cups worth so way less than a gallon. if he tops it off with diesel will he see problems? the truck was just parked after he filled it so it hasnt really been run. What to do? what problems will it cause? thanks in advance!
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #2 of 15 Old 06-20-2013, 08:16 AM
If it was truly and justly a couple of cups, as in 2 8oz cups, then it won't hurt. If anyone is exaggerating to try to minimize the situation, well then...This would be the time for truthful and honest talk.
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #3 of 15 Old 06-20-2013, 10:30 AM
Ok, I have heard there are two different kind of diesel truck drivers. First owners who have put gas in the fuel tank then second owners who eventually will. I pulled up to a gas station and was looking for the green pump handle because that usually means diesel. Not at this particular station, I started pumping and 8 gallons later I noticed it was gas. I immediately pulled forward and topped off my tank with diesel. Drove her home 15 miles, parked and next morning I was draining my fuel tank. Went and got 10 gallons of diesel, cranked up the truck, drove to the gas station and put a full tank of diesel in it. Now that was on my 7.3 and she showed no ill effects of my stupidity. I for one do not think your father's truck will suffer any, the gas would be very diluted. Hopefully I'm right.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
post #4 of 15 Old 06-20-2013, 10:41 AM
It may ignite at a slightly lower compression, which would be called pre-detonation. Depending on the densities, which I am too lazy to look up, we could calculate the dilution and new combustion temp/pressure with the gas in the fuel. However, assuming a 30 gallon tank with 16 oz of gas, you're looking at around:
30 gal * 128 oz/gal = 16,640 ounces total.
16/16,640 = 0.001 or 0.1% gas.
Seems harmless to me. There's probably more water in there than gas
Expirobo is offline
post #5 of 15 Old 06-20-2013, 10:45 AM
usteffenhagen's Avatar
I don't know too much about the newer diesels but I'd think it would be ok. I kno that guys up in Alaska will put a gallon of gas in the fuel tank so their diesel won't get too thick and sludgy in the winter time
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #6 of 15 Old 06-20-2013, 11:13 AM
I called my father when I had my mishap and he told me the same thing about putting in a gallon of gas when the winters got really cold. 18 wheeler
Blue Spring Mod
SCT Livewire ts
post #7 of 15 Old 06-20-2013, 12:20 PM
I got a buddy of mine back up in Oregon filling up his 7.3 at the filling station and in Oregon you can't pump your own gas so the high school punk filling the truck put the gas nozzle in there, started pumping and walked away. Only about a gallon and a half got put in so it was ok luckily he spotted the black nozzle. I was surprised to find out my buddy didn't kill the d*** head kid
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 15 Old 06-20-2013, 02:13 PM Thread Starter
Red '97's Avatar
sounds like the generally consensus here is to fill it and drive it. were dropping the fuel tank and draining it anyway cause he doesnt wanna risk it, were taking it on vacation next week. thanks a lot for the input guys, much appreciated
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
post #9 of 15 Old 06-20-2013, 02:38 PM
6.0f250firstcar's Avatar
Go ahead, but it is honestly a moot point IMHO. All you're be doing is wasting precious diesel.
Ryan
6.0f250firstcar is offline
post #10 of 15 Old 06-20-2013, 03:20 PM
Well, I had the exact opposite problem....LOL. Back in February when I was up north snowmobiling, I filled my sled up with diesel. I flipped is over and dumped it out and filled it up with gas. Needless to say, I was the joke that weekend.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
