Oil pump gear removal from crankshaft? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-19-2013, 09:28 PM Thread Starter
Am I missing something here? The gear part of the oil pump will not slide past the front collar of the crankshaft. Im lost....trying to replace the timing cover.
02' Ford Lightning---- twin turbo'd
08' King Ranch F250 - egr/dpf deleted; tuned
Casey02L is offline
post #2 of 3 Old 07-14-2013, 09:25 AM
99coalroller's Avatar
Im having the same problem right now. Anyone know the trick to get it off?
2005 King Ranch CCLB EGR Delete, 5" MBRP
99coalroller is offline
post #3 of 3 Old 07-16-2013, 07:50 AM Thread Starter
There is a sleeve or wear wear ring/collar over the end of the crank. It must be removed before the oil pump gear will come off. If you look at the new front seal set it will come with a new wear sleeve. You are suppose to use special tools to remove the old sleeve and install the new sleeve/seal. I made my own special tools to press the sleeve on..... 2k+ miles so far and no leaks yet.
Casey02L is offline
