2008 f250 6.4 skipping are misfire. - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-18-2013, 07:36 PM Thread Starter
When taking off from stop are slow roll truck acts like it's skipping but not all the time . New fuel filters and trans flush less than 2000 miles.
Gunsmoke 64 is offline
post #2 of 10 Old 06-19-2013, 07:56 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Any codes? I suggest getting it checked. If its an injector you don't want to wait till it melts a piston
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 10 Old 06-19-2013, 08:12 AM Thread Starter
No codes didn't no if they and check without a code .
post #4 of 10 Old 06-19-2013, 09:56 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Are you losing coolant? Is there white smoke?
08 F350 cc/sb 4X4
post #5 of 10 Old 06-19-2013, 10:38 AM Thread Starter
Need to check coolant. It was raining when it happened looked thought I seen soom smoke but was hard to tell . First time it happened surprised me so didn't look.
post #6 of 10 Old 06-19-2013, 01:25 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
There is a tsb about moisture collecting in the intercooler and it causes the conditions you are describing. I am not sure what the tsb number is tho. I have seen it on this sight. Does your truck only do it when its raining?
08 F350 cc/sb 4X4
post #7 of 10 Old 06-19-2013, 04:04 PM Thread Starter
No but it has,been raining a lot . On way home played with truck noticed when I first push peddle pretty hard its like to much fuel back off peddle a little seem to run better only does it before shifts gears.
post #8 of 10 Old 06-20-2013, 06:48 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Here is the tsb i am talking about. Might look into it if it exhibits these conditions when there is high humidity.
intercooler tsb
08 F350 cc/sb 4X4
post #9 of 10 Old 06-20-2013, 11:57 AM Thread Starter
Thanks I need to check it out.
post #10 of 10 Old 06-20-2013, 12:32 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem. Keep us posted on your issue
08 F350 cc/sb 4X4
