Anyone use HID bulbs without projectors? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-10-2013, 06:31 PM Thread Starter
Reason I ask, I have been talking to a sales rep from V-LED (which is where I got LEDs for my Tahoe and love them!) about their HIDs since they don't make LEDs for the H13 bulbs. I asked if they have a retrofit system like I've seen around here and copied a pic from the retrofit site of their projectors. And I told him that I've read here that if you don't use them you'll blind oncoming traffic if you don't use them. He said there is some truth to that but almost all late model vehicles have highly engineered housing reflectors with a controlled beam pattern. And with adjustment of the beam won't blind oncoming traffic.
Just wondering if anyone here has installed the lights without a projector has any input?
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 12 Old 06-10-2013, 07:10 PM
Spunky's Avatar
I have hids in both head lights and the lower driving lights. I love it!! Did not change to projected head light assembly. Now the main head lights work well with hids and there Is hardly any blinding to on coming traffic. Now hids in the lower driving lights well there CRAZY bright!! Also I noticed when trying to use the high beam with hids is pointless at lest in my truck. The beams go every where so I don't use highbeams any really there is not much of need with hids. I'm running 6000k in both upper and lower and I drive a 2008 f350
Hope this helps
2008 F350 Super Duty Crew Cab Short Box
No mods as of yet.
Spunky is offline
post #3 of 12 Old 06-10-2013, 07:44 PM Thread Starter
Ok thanks, I really want to do something, my high beams suck butt! Guess I could try it without the projectors and if I want/need to I can convert the housings later.. What brand did you go with? Do the 6k look blueish? I put 5k LEDs in my Tahoe and love the white light.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #4 of 12 Old 06-10-2013, 07:53 PM
Spunky's Avatar
6000k is just the start of blue is both white and blue. I personally don't see any need for projectors once the hids are in. But thats me. As for brand I can't remember but there a local brand made here in Vancouver bc Canada. But as for cost they were around 250 per set. Also if you do the lower lights to make sure the ballist is mounted up high. I went through a few cause they kept getting wet. I mounted mine on the side of the headlights and since the no problems
No mods as of yet.
Spunky is offline
post #5 of 12 Old 06-10-2013, 07:57 PM Thread Starter
I read on V-LEDs website that the ballast can still work under water. That's reassuring especially if you mount it up high. I may go that route
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #6 of 12 Old 06-10-2013, 08:02 PM
Spunky's Avatar
Well I was told that there waterproof to and after going through 4 sets I had enough. The connects look like they should be able to handle lots of water and not let anything in but for and 4 sets later I got tired of changing them all the time. Just a tip from my experience good luck and enjoy being able to see the road much better then those crappy stock lights
No mods as of yet.
Spunky is offline
post #7 of 12 Old 06-10-2013, 08:09 PM Thread Starter
Thanks for the tip
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #8 of 12 Old 06-11-2013, 04:09 AM
superduty6.4's Avatar
I've also got them in my original headlight housing without projectors and they work great. As long as I turn on my fog lights when I pass traffic I don't really ever get flashed.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #9 of 12 Old 06-11-2013, 06:09 PM Thread Starter
How do HIDs compare to stock lights in temp? Do they run cooler?
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #10 of 12 Old 06-12-2013, 04:13 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
i run ddmtuning HID's in head lights and fogs and just re-aimed my headlights and never get flashed. no complaint and the light output is awesome!
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
