Found this in water/fuel separator??? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-10-2013, 10:59 AM Thread Starter
Thumbs down Found this in water/fuel separator???
So I started to have that annoying drain water/fuel separator problem even after draining the separator. I finally did another oil change and replaced all my filters. Well this is what I found when I cleaned out the bottom fuel filter n sensor area. What do you all think this crud could be? I'm wondering if its old material from maybe a previous filter the previous owner never changed. This is my 2nd oil change n fuel filter change on the truck.
grimreaper is offline
post #2 of 7 Old 06-10-2013, 11:04 AM
theplumbingmedic's Avatar
Yipes that looks nasty. I`m curious to see if anyone knows what it is as well
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #3 of 7 Old 06-10-2013, 04:36 PM
Quoted: 45 Post(s)
Looks like dirty fingers. Maybe you could get some info from the prints.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #4 of 7 Old 06-10-2013, 07:52 PM
Looks like it might be bacterial growth. It happens. It's probably the same thing that's causing your water separator light to come on so often. You probably need to clean out the separator. You'll need a gasket kit, about $40, and some brake cleaner or something similar.
B. Adams is offline
post #5 of 7 Old 06-11-2013, 04:07 AM
Clean that bowl VERY good before you put new filter in and run it again. Looks like algae growth to me. If you do not get it clean it will grow back.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #6 of 7 Old 06-11-2013, 04:22 AM
ThomasvillePavers's Avatar
What he said, I had the same in mine once and Brake Kleen with new seals did the trick
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #7 of 7 Old 06-11-2013, 05:41 AM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
LOL
flashover1969 is offline
