Power entry step - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-08-2013, 07:04 PM Thread Starter
Power entry step
My wife has knee problems and climbing in and out of my Lariat with 20" wheels is not helping. I have the Ford factory oval nerf bars. Does anyone know of a power step that extends when the door is opened and retracts when door is closed? If it can be added to the truck with the nerf bars and provide a step somewhat lower than the nerf bar. Like she could step up on the power step then on to the nerf bar and then into the truck. I have Googled but not found anything.
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 2 Old 06-08-2013, 07:19 PM
ATVJOE's Avatar
Look at the AMP power steps, that's what I have on mine and love em.
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
