Looking for stronger U joints - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-06-2013, 07:26 PM Thread Starter
I was wondering if anyone knew where I could get stronger than stock u joints to replace on my rear drive shaft?
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 8 Old 06-07-2013, 06:00 AM
Great question.....I would like to know too.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #3 of 8 Old 06-07-2013, 11:46 AM
Are yours broken or worn out?
tensixniner is offline
post #4 of 8 Old 06-08-2013, 08:24 PM Thread Starter
I was told they are getting warn and I was just wanting to eliminate a weak link in the drive train
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #5 of 8 Old 06-08-2013, 11:02 PM
I don't think the rear driveshaft u joints are a weak link. They are a 1410 series joint which is pretty strong. You can go to a 1480 u joint but thats completely overkill, and you'll need to get your shaft modified to use them.
Spicer and NEAPCO have greasable and permanent lube ujoints available.
Permanent sealed are usually stronger because the cross isn't drilled for grease passages. I prefer being able to grease them.
I can't remember the part numbers but they both have catalogs online.
My preference is NEAPCO because they are made in the USA. I found out after I replaced my rear ujoints with the Spicer Ones that only the caps are made in the USA the rest came from China.
post #6 of 8 Old 06-09-2013, 04:32 AM Thread Starter
Thanks ill look into them
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #7 of 8 Old 06-09-2013, 01:01 PM
44magnum's Avatar
Quoted: 2 Post(s)
Yup 1410 series. I would go with Spicer. If you want max strength go with sealed/non-greasable, but I would go with the greasable ones as they will last longer.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #8 of 8 Old 06-09-2013, 01:08 PM
Redrock2000's Avatar
Quoted: 2 Post(s)
Funny this post came up as I was needing to check mine. I was wondering if y'all new of what upgrades work stock sled pullers do to their drive shafts and u joints? Seems like that's what's broken the most when pulling.
I don't care how they do it in Japan
Redrock2000 is offline
