6 MPG When pulling 38 ft toy hauler - Ford Powerstroke Diesel Forum
post #1 of 46 Old 06-03-2013, 10:18 PM Thread Starter
Quoted: 2 Post(s)
What are you guys getting for fuel mileage with larger 5th wheels?
I have a 2008 crew cab 4x4 with 6 inch lift on 20 inch wheels with 35's. Truck has 3:73 gears and is all stock.
Toy hauler is 38.5 ft and weighs 12,000 without cargo. With cargo it weighs in at 14,500 lbs. Toy hauler has a 7 inch lift also.
Truck only gets around 6 MPG when pulling 65-70 mph. Does this mileage seem low or is this the norm when pulling that much weight? When pulling on flat land to sand dunes only get 6.5 mpg and average 5.5 to 7 when pulling up in the mountains. The 5.5 is going up there to camp and 7 mpg is coming back down.
Do you think re gearing the truck will make a big difference? Truck is a turd when pulling up big hills and will not maintain 65 mpg speed limit. Truck will maintain 50 mpg without keeping it pinned to floor. Tires and lift are killing me. Truck starts bogging down then drops 2 gears and runs between 2500-3000 when pulling hills. I don't want to pin it to the floor cuz I have no idea how high EGT's get up too.
If I had it to do over again, I wouldn't pull with a lifted truck. It's nice when heading to sand dunes or off reading but rest of the time it sucks.
Just wondering what the rest of you guys are getting. Dirty max guys with similar setups are claiming 9 to 10 mpg. It cost me almost .70 cents a mile when pulling my toy hauler
Blue Turd is offline
post #2 of 46 Old 06-03-2013, 10:48 PM
Capt dong's Avatar
Quoted: 5 Post(s)
your lifts arent helping at all.
do you have any engine mods?
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 46 Old 06-03-2013, 11:14 PM
cbenn's Avatar
Quoted: 2 Post(s)
You are getting about the best your going to get, I pull a 35' 5th wheel weighs out @ 14,740, I have mods listed and use the Spartan 210 Tow performance tune and get a steady 12/13, need to delete, get the truck breathing and you should improve to around at least 10/11. Good luck!
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is offline
post #4 of 46 Old 06-04-2013, 09:57 PM Thread Starter
Quoted: 2 Post(s)
No engine mods
post #5 of 46 Old 06-04-2013, 10:01 PM Thread Starter
Quoted: 2 Post(s)
I would be very happy if I could get 10 mpg pulling toy hauler. You have a ton of mods. So tuner, DPF delete, exhaust, intake tube and air filter filter might pick up 3-4 mpg?
post #6 of 46 Old 06-04-2013, 10:25 PM
Capt dong's Avatar
Quoted: 5 Post(s)
as stated do your mods and drive conservatively and you will gain mpgs.
also youre near the legal limit of towing capacity so youre engine is working hard to pull it.
08 F250 KR
08 F250 XL
post #7 of 46 Old 06-04-2013, 11:50 PM
F450Harley's Avatar
The poor MPGs are caused by your rear (3.73 ratio) . Being lifted makes it a little worse.
3.73s are the best rears when driving empty, esp. at higher speeds or towing lightly.
You might ask up to what ?
IDK. You have to play with it to find out.
Now when you look at your truck's rated capacities, that dosnt mean........ you cant max it, but dosnt mean you will get decent mpg either.
3.73 gears is your ratio on 4th (the speed your TC locks). Under load & stress your tranny downshifts........so now you are on 3rd with a ratio of 5.70 or so and if that is inadequate for the load, it will throw it on 2nd with a ratio of 8.some witch is alot higher than.........say 4.30 ratio on my 450.
That results in your engine reving up & dumping fuel thus giving you those kind of MPGs.
Title on hand like always
F450Harley is offline
post #8 of 46 Old 06-05-2013, 12:03 AM
F450Harley's Avatar
You might wanna look in here under "swap or for trade" section for someone wanting to get your low gears for their higher ones.
I think, judging by what you pull, you will be ok with 4.10s (but dont hold me to that).
Hopefully someone with rear gearing experience will chime in.
post #9 of 46 Old 06-05-2013, 11:49 AM
Delete and tune would be cheaper, easier and make more of a difference than gears. Just in my opinion but most will agree.
2008 Silver F-250 6.4
griz700rocket is offline
post #10 of 46 Old 06-05-2013, 01:36 PM
As others have stated, getting deleted and tuned will help improve MPG, but IMHO slowing down will give the most improvement. I have a 37 ft. Toy Hauler and the first time I towed with it I got 7.5 on the lie-o-meter. That was trying to maintain 65 to 70 MPH, even going up hills. On the trip back I traveled at 62-63, and never let the boost go above 20 lbs. Going up hills and not letting boost go above 20 lbs. meant it would go slower. On the larger hills it would drop back to fourth gear. Keeping the discipline to never go over 20lbs of boost netted me 10 MPG on the lie-o-meter. The big tires are also hurting you as you are not in the right rpm range. I don't think the lift is hurting you much when you are towing, as the fiver is a lot taller than the truck. If you still have the stock ST tires on your fiver, they are only speed rated to 65 MPH anyway.
RDUB is offline
