Hub assembly? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-29-2013, 09:40 AM Thread Starter
Michi6.4's Avatar
Hub assembly?
Hey guys i just replaced all for rotors and pads. I spun my drivers side hub with out the tire and it sounds a lil dry? Is this something i can take apart and grease or do i have to spend 500 on the hub assembly? Thanks guys!!
08 F-250 CCSB mini maxx, K&NCAI, 5"DP back, 20" Dropstars Monster Energy edition, 33" Toyo M/Ts
Michi6.4 is offline
post #2 of 3 Old 05-29-2013, 10:00 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I believe they are sealed and have to be replaced. Hopefully someone else will confirm.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 3 Old 05-29-2013, 10:10 AM
Yup, you are stuck buying the whole unit. Look around online and you can get them cheaper than at the dealership.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
