heated seat/power mirrors issue related? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-26-2013, 02:58 PM Thread Starter
Hey there,
I recently picked up an 08 F350 with the 6.4 and since i picked it up the power mirrors and heated seats haven't worked. The folding and telescoping function work on both mirrors but cannot adjust the mirror itself. As for the heated seats neither side work the light comes on when you enable but doesn't turns off shortly after. I have checked the fuses several times but came up empty handed. Could these be related? Does anyone know what colours the wires are for the heated seats so I can check for power? What about the mirrors? I am thinking about trying a new switch but not confident thats the issue.
Thanks!
theputz is offline
post #2 of 12 Old 09-10-2013, 09:05 PM Thread Starter
can anyone help?
theputz is offline
post #3 of 12 Old 09-11-2013, 07:15 AM
CNYWhiteDually's Avatar
have you checked all your fuses?
CNYWhiteDually is offline
post #4 of 12 Old 09-11-2013, 07:36 AM
69Stang's Avatar
Power mirror switch is fuse #12, which also controls Driver Power Seat. Fuse #18 is the heated seat relay. I'd recheck those 2. This is on 2010's, I'd think it'd be the same on a 2008.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #5 of 12 Old 09-11-2013, 08:06 PM Thread Starter
fuses checked out fine. i am baffled.
theputz is offline
post #6 of 12 Old 09-12-2013, 04:47 AM
I have the same issue as far as the heated seat just havent had a chance to fix it yet but from what i have read there is a relay under the seat you should here it click when you press the button if it clicks then it is one of your heating pads has gone out. If it doesnt then check you have power coming to it, if so then replace your relay. Your heating pads are wired in series so when either the back or bottom pad shorts out the whole seat quits. its normally the driver side that goes out first do to more constant use. also fuse #f18 is in the passenger side floor board only mention it cause I didnt realize I was checking the wrong one till the wife pointed it out to me in the owners manual.
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
Last edited by thnderchcken; 09-12-2013 at 04:54 AM. Reason: improper nomenclature
thnderchcken is offline
post #7 of 12 Old 01-30-2016, 11:31 AM
bigtuna401's Avatar
Quoted: 4 Post(s)
Can the heating pads be replaced?
2008 F-250 Lariat CCSB 4x4
EGR & DPF Deleted
Spartan Tuner
S&B CAI
bigtuna401 is offline
post #8 of 12 Old 01-31-2016, 05:12 AM
Ranzan's Avatar
Quoted: 20 Post(s)
do you have memory seats?
if so it might be the connections or the actual memory box under the drivers side seat
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
Fully deleted DFC Long Block
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #9 of 12 Old 02-02-2016, 06:37 AM
bigtuna401's Avatar
Quoted: 4 Post(s)
no memory seats.
EGR & DPF Deleted
Spartan Tuner
S&B CAI
post #10 of 12 Old 02-03-2016, 04:04 AM
Ranzan's Avatar
Quoted: 20 Post(s)
sorry big tuna i thought this was an active thread and was replying to the original poster
.... lol yes you can replace the pads and they are fairly simple to do
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
