Probably gonna catch alot of crap for this. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-23-2013, 06:58 PM Thread Starter
SySx's Avatar
Looking at a 08 450 2wd dually with the 6.4 and 50k miles on it.My question is does someone make a lowering kit for it? a 3/5 or 2/4?
93 Chevy Blazer R.I.P. Baby
03 Ford Lighting 500 hp SOLD
09 Dodge Challenger R/T SOLD
03 Ford F350 Crew Cab 4x4 SOLD
08 Ford F350 CCLB Dually Mini Maxx Race Tuner, Turbo Back Flo Pro 4" straight pipe dual exhaust
SySx is offline
post #2 of 7 Old 05-23-2013, 07:33 PM
dt23400's Avatar
someone has to. ive seen plenty of sweet lowered duallys.
2005 rclb 6.0 f250
372k 4inch exhaust sct x4 stock tunes 54 ficm
2002 gtp precision t62 turbo zzp turbo cam zzp tranny 65lbs injectors 505whp 25psi
2006 sti stage 2
dt23400 is offline
post #3 of 7 Old 05-23-2013, 10:02 PM
F450Harley's Avatar
I dunno why any one would give you crap about it.
The good thing is............ being a 2WD..........but being a 450, would limit your choices.
A place to start is DJM suspension. If they dont make anything for a 450, they might be able to steer you in the right direction. Good Luck to you bud.
I think, I remember seeing a lowered dually thread in here. You might wanna check it out.
Title on hand like always
F450Harley is offline
post #4 of 7 Old 05-24-2013, 01:03 AM Thread Starter
SySx's Avatar
I've looked around quite a bit and the 450 is more heavy duty I guess. Either way i'm gonna keep looking cause this truck seems like a sweet deal I just don't wanna be able to do what I want with it.
SySx is offline
post #5 of 7 Old 05-24-2013, 02:43 AM
john galt's Avatar
Quoted: 1327 Post(s)
hey man it is YOUR truck you should be able to do what ever you want with it
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #6 of 7 Old 05-24-2013, 07:29 AM Thread Starter
SySx's Avatar
Would it be possible to remove a leaf in the back and take out the blocks? That would be a good amount of drop right there.
SySx is offline
post #7 of 7 Old 05-25-2013, 04:46 PM
WoodBoy's Avatar
Most people on the SRW 250s and 350s buy 5.4 coils. There are three different part numbers for three different spring ratings. 4400, 4800, and 5200# IIRC. Most run the 4400 coils in the front and take out the rear block. Your front end should be the same
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
