How much coolant to drain?? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-22-2013, 10:51 AM Thread Starter
rt_hawk's Avatar
I have my egr coolers coolant flow bypassed, but I found a different hose set up that I like better to bypass it, it's a formed silicone hose that starts as a 1" ID hose, then turns into a 3/4" ID hose...so I would only need 2 clamps...plus I want to use spring corbin clamps instead of the worm drives I am using now...would I be able to just drain the radiator until empty so I can avoid a shower in red antifreeze? Or would i need to drain from another place to get rhe coolant lower than that?? In a stock truck it would be just like replacing the bottom egr cooler and top egr cooler hoses...
Thanks in advance!
Sean
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
