Leveling kit? aftermarket springs? help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-20-2013, 03:49 PM Thread Starter
dt23400's Avatar
K guys im fighting a steering problem. my track bar bushing is bad and im trying to see if i need an adjustable one or a drop mount. my wheel sticks out farter on the driver side than it does the passenerger side. now this was a boarder patrol truck so i know it has different suspension. My coils are blue. i assume that isnt factory. the truck sits front high. i believe i have a factory spacer on the coil.
2005 rclb 6.0 f250
372k 4inch exhaust sct x4 stock tunes 54 ficm
2002 gtp precision t62 turbo zzp turbo cam zzp tranny 65lbs injectors 505whp 25psi
2006 sti stage 2
dt23400 is offline
post #2 of 7 Old 05-20-2013, 08:46 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, if you want the axle to be centered then get an adjustable track bar.
If you get a drop mount, then you also need to get a dropped drag link to match, otherwise you will have bumpsteer!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 7 Old 05-20-2013, 08:50 PM
tony97gt's Avatar
I'm installing a leveling kit that has blue springs. It's a 2.5". Does that mean I need to buy additional hardware?
Sorry to hijack. Maybe we have the same springs.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #4 of 7 Old 05-20-2013, 08:54 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
You don't have to if you don't mind having your axle a little off-centered.
I ran a Daystar 2-3/4" leveling kit on my truck for a year and had no problems running the stock parts with it.
GregsSD is offline
post #5 of 7 Old 05-21-2013, 05:53 AM Thread Starter
dt23400's Avatar
Yea non centered bothers me. I notice things like that. Anyone ha a link to an adjustable that works for leveling kits?
2005 rclb 6.0 f250
2006 sti stage 2
dt23400 is offline
post #6 of 7 Old 05-21-2013, 06:18 AM
Going through the same thing, especially since adj track bars are not cheap, but here are the cheapest I've found; BD Diesel Performance Ford Adjustable Track Bar Kit
and
BD-Power Adjustable Track-Bar 1032110
Not sure if the 10% off works at XDP but I'll probably order from them when I order an exhaust tip in a month or 2. EDIT: May10 is 10% off XDP, so I will probably order that sooner than later. Leveling kit is supposed to go on tomorrow, blocks following that unless I have them today before truck goes to shop. Figure this looks like an easy install much like the blocks for the rear and can handle that. The front end was not going well when I tried to do the leveling kit and I just said screw it.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #7 of 7 Old 05-21-2013, 06:38 AM Thread Starter
dt23400's Avatar
Wonder if the ball joint flip would work
2005 rclb 6.0 f250
2006 sti stage 2
dt23400 is offline
