Tow Haul not working - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-19-2013, 12:01 PM Thread Starter
NCfarmboy's Avatar
Tow haul isn't working on my 2008 F-250. Running an H&S tuner. If I push the button 20+ times, sometimes it will come on...
I read on another forum it's likely a broken wire in the shifter. Anyone else have this issue? Is it easy to fix?
2014 F-250 KR<><
SCT - Rudys Tunes - Deleted
NCfarmboy is offline
post #2 of 3 Old 05-19-2013, 02:51 PM
Powerstroke Techie
It's likely in the shifter handle itself.
The older trucks used to rub the wires through at the bottom of the shifter. I've changed a couple of the late model shift handles, but the wiring or switch must have been defective in the lever itself, since there was no visible damage to the wiring that is exposed.
Get the wiring diagram and you will need to momentarily jumper the wiring at the column side of the harness to ensure that the circuit integrity is still there from the column to the PCM. Hope this helps.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 3 Old 05-19-2013, 04:38 PM
pwrstrokin6.4's Avatar
i have the same issue but if i put my truck in park, it works everytime. im thinking the wiring is chaffed or broken and when it park it makes contact again.
pwrstrokin6.4 is offline
