Goodyear ATS tire pressure - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-11-2013, 07:00 PM Thread Starter
What pressure are you guys running if you have Goodyear ATS 275/60/r20's? My door sticker says 65 psi, but I think on the tire is says 85 psi cold.
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 5 Old 05-11-2013, 07:04 PM
W9GBB's Avatar
I've been running 65 PSI in mine since new, haven't has any problems.
2008 F-250 4x4 CC SB Lariat, All Options
Spartan Tuned
S&B Intake
W9GBB is offline
post #3 of 5 Old 05-11-2013, 08:12 PM
Side wall pressure is max pressure cold that you can set the tire too. If you read the sidewall small print it will tell you to follow vehicle manufacturer specs for pressure.
Go withe the door sticker.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #4 of 5 Old 05-12-2013, 06:22 AM Thread Starter
Thanks Guys, 65 Is What I've Got.
wargle is offline
post #5 of 5 Old 05-12-2013, 12:10 PM
rt_hawk's Avatar
I use the tire and rim association inflation table to find out the proper psi for my tires per weight each tire holds... Here is the table, figure out the curb weight of your truck and divide by 4, look up your size and use the weight you got by dividing by 4 to find the optimal psi for each tire, of course being loaded down/towing changes psi requirements. The psi ford puts on the door is for a fully loaded truck, they figure better safe than sorry and tell you to onflate to full capacity levels. You can safely air down to TRA psi levels for better ride and tire wear...
http://toyotires.com/sites/default/f...ationTable.pdf
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
