DPF Regen Frequency and Notifications? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-10-2013, 09:44 PM Thread Starter
I took a leap of faith and bought a 2008 F250 after reading and reading and reading about everything on every forum for weeks. I absolutely love the truck. It has 140500 miles, 1500 of which I've put on it so far. Anyhow, the first thing I was concerned with was obviously my EOT/ECT and DPF. I bought a Scangauge to use on all of my test drives before I bought anything.
So far, I have been watching my display and EGTs without and indication so far in the last 1500 miles of a DPF regen. I literally drove 250 miles one day just to watch it regen and I still haven't been able to get any indication that it is happening. Yes, there is a DPF and no tuner on the truck (yet).
I know it will regen at some point, but is this normal to go so long without happening? I see my EGTs going from 450-650 depending on level or grade driving. I leave my dash display on the average MPG screen. From what I've read, it will flash me a quick note about cleaning the exhaust system and go away when in regen and my EGTs should spike for some arbitrary duration until complete.
Expirobo is offline
post #2 of 7 Old 05-11-2013, 05:20 AM
superduty6.4's Avatar
1500 seems like a very long time without a regen. Are you sure the dpf is still installed? If it is then is it possible that it may just be hollowed out?
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 7 Old 05-11-2013, 05:35 AM
ADMIN AND TECH
SCUFFY828's Avatar
Quoted: 3 Post(s)
if this truck has never been reprogrammed with the latest calibration at some point , it is possible for the display to not give you a warning when it is in regen , i have heard this complaint before and have spent some time with a couple trucks where they didnt , some of the early production trucks ive been involved with never gave warning but with that said , the vehicle did have a slight loss of power when in regen even without the warning
ITS STOCK
SCUFFY828 is offline
post #4 of 7 Old 05-11-2013, 09:09 AM Thread Starter
I'm not sure if that it hasn't done a regen since I bought it, especially with 140k miles. The Oasis report says the PCM was reflashed as a recall/TSB at 60k miles. I'm not sure that it will indicate that it is in regen unless I know what flash was installed. Anyhow, the DPF is not hollowed out to my knowledge. Regardless of the PCM flash, the EGTs should spike to somewhere around 1000+ degrees right?
Expirobo is offline
post #5 of 7 Old 05-11-2013, 12:35 PM
Yes you should probably see that or even a little higher.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #6 of 7 Old 05-11-2013, 05:53 PM
I bought my 2008 new. It now has 167K. On my truck Regen occurs between 150 and 300 miles depending on type of driving.
Several years ago I bought a Dashdaq/spartan mainly for monitoring the 300 plus Ford specific parameters. One of which is regen active. I have the latest flash updates. When my truck goes into regen the EGT cycles between about 1000 and a max of 1350 driving between 60 and 65 MPH. At that speed the regen completes in 15-20 miles of driving. The regen notification will flash on the dash but I rarely notice the light. I do monitor the regen active signal on the DashDaq/Spartan, so I know when regen starts and ends.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #7 of 7 Old 05-11-2013, 09:34 PM Thread Starter
If only there was a code that would indicate regen status on the scangauge. I bet there is a CANBUS hex code that I can monitor that will show me the bit's status on the system.
I might call them to see if they have something that I can program in to show it. Anyhow, not toooooo worried about it but I want to get a baseline on the regen frequency to keep track of the health of the DPF.
Expirobo is offline
