NewB Here - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-08-2013, 10:44 AM Thread Starter
NewB Here
2010 6.4 Mods are MBRP Down pipe back, Intake, Spartan tuner,
I have read so much about this truck, installed the 175 dpf delete tune. My?, or concern is what to do with the EGR, not taking it out for a while and not doing a delete kit for a while. Also any transmission issues I should worry about with some of these tunes. Guess I need peace of mind this is all going to work. Thanks for any input.
jager250 is offline
post #2 of 6 Old 05-08-2013, 03:51 PM
pops250's Avatar
If you're worried about something breaking just drive it like you cant afford to fix it.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #3 of 6 Old 05-08-2013, 03:59 PM
If you are worried about truck problems then keep the tune on the low side and drive it easy. Any reason why you arent taking out the EGR? Not sure where you live but diesels around here dont go through emissions so I would have taken that out before I did anything.
2000 F250 Reg Cab XLT 4x4-stock... for now
Turb-Boost is offline
post #4 of 6 Old 05-08-2013, 04:59 PM Thread Starter
Help,
So, I can do egr delete, coolers, this will not allow hot gasses through turbo? Need to wait a couple of months for some funds. Also leaving it on with a low tune should not kill anything right. Is it good to delete with tune and still have it installed, I here different stories,
jager250 is offline
post #5 of 6 Old 05-08-2013, 09:15 PM
fairhaven's Avatar
Yes do the egr/cooler deletes. Flo Pro makes a nice kit with a stainless high flow intake elbow. Your truck will thank you.
2010 F350 Lariat FX4 CC Long Box, Line X, Pueblo Gold, H&S Mini Maxx, DPF/DOC Delete, Flo Pro Down Pipe Back Stainless Exhaust, Flo Pro EGR/Cooler Delete with High Flow Intake Elbow, S&B CAI, MBRP Exhaust Tip
fairhaven is offline
post #6 of 6 Old 05-08-2013, 11:11 PM
john galt's Avatar
Quoted: 1400 Post(s)
Welcome to the org
ALSO
In line with this thread, How well does the egr delete via programmer work? I installed the BPD egr as I could be a victim of a visual inspection and wanted an intact egr just in case.
I would however like to program out the damn thing with my sct. Just wondered how effective that is and what anyone knows about going this route?
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
