half shaft play - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-06-2013, 11:32 AM Thread Starter
half shaft play
OK well when changing my oil today I was checking some things over while I was under the truck. On both my driver and pass sides if I grab the half shaft at the u joint I can wiggle it back and forth. The u joints them selfs seam fine so I thought it must be the hubs. I jacked the front of the truck up and I have no slop in the wheel top to bottom or left to right. What would cause this problem? I still kinda lean towards the hubs but not trying to pay $500 each for hubs just to hope its the problem. Also since I have owned the tuck about 15mo now if im going slow and make a tight turn you can feel the front bind up a bit in the wheel. Now this isn't horrible and most wouldn't notice it. I tend to just do my best to not turn it really tight. Any input would be much appreciated. Thanks in advance .
bwhicker649 is offline
post #2 of 2 Old 05-07-2013, 11:13 PM
The axle essentially floats between the inner differential and the outer hub, some movement like that is perfectly normal.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
