2008 6.4 Filter Back exhaust - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2013, 08:30 PM Thread Starter
Question 2008 6.4 Filter Back exhaust
OK so my dad has a 2008 6.4 powerstroke, Super cab long bed with a Reading utility body, SRW. My dad is getting pissed because the truck constantly gets 11.2-11.8 mpgs. when he got it it got around 9-10 then we drilled about a dozen 3/4 holes in the air box cover with a hole saw and it went up into the 11 range. To be honest this is still horrible, his 7.3 before this thing got like 14-15 all day long even when we towed or hammered on it!!
i was just wondering, has anyone done a filter back exhaust system? like a 4" straight pipe all the way out. I know this would delete the muffler and the other little can on the tailpipe which in turn would lower EGTs a bit and from what they say boost HP. i know it wont make it much louder because of the STUPID cat and DPF.
We were going to do the CAT/DPF delete, but with him being a contractor, he didn't want to have to deal with the state cops up here in MA because they have been cracking down and checking almost all commercial guys trucks out very thoroughly, and of course its illegal to delete the emissions.
So long story short has anyone seen MPG increases with an ONLY FILTER BACK straight pipe, and would it cause any problems without the finned tip to cool the DPF?
help us out guys, we decided to come here before just throwing money around!
thanks
-Zac and Nate
zolson is offline
post #2 of 12 Old 05-02-2013, 08:34 PM
srjd's Avatar
Quoted: 2 Post(s)
Filter back exhaust is a huge waste of money and purely for looks
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 12 Old 05-02-2013, 08:42 PM
I agree, filter back is going to provide little performance gains and the muffler adds to comfort in the cab.
cfd_shop is offline
post #4 of 12 Old 05-02-2013, 09:01 PM
diesel23's Avatar
Quoted: 7 Post(s)
Feedback Score: 14 reviews
What these guys said ^^ , i did a mbrp dpf back exhauast and wasted my money ,use it towards the full dpf delete , egr delete ,coolant filter set up or bypass oil filter kit ,
diesel23 is offline
post #5 of 12 Old 05-02-2013, 09:05 PM Thread Starter
at this point i think my father is very much against the DPF delete, considering the good tuner, the H&S, is 1200 bucks with the delete tunes, plus the exhaust pipes is about another 300 or so. its not cheap, plus the fines for running a deleted truck, as much as i want him to do it, can really hurt the wallet. if it was a passenger truck i would make him delete it, but since its commercial and for work its much more liable to being checked out by the EPs and such. which suckkss
zolson is offline
post #6 of 12 Old 05-03-2013, 08:26 AM
Maybe consider a DPF delete with a H&S Mini and hollow out the DPF....leave it on for visual purposes. If you run a mild tune with 0 LBF (Low Boost Fueling), the truck will not smoke much at all....problem solved? The only problem with that is you will need to keep the EGR coolers on, but that is not that big of a deal. Don't get me wrong it would be beter without those coolers too, but the 6.4's don't have nearly as many failures as the 6.0's did.
Good Luck,
Karl (Turbo kidd)
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #7 of 12 Old 05-03-2013, 09:20 AM Thread Starter
Yea we thought about that too, but then at that point if it comes to the point where you want to put the dpf back on to sell it or trade it in, its 3 grand for the DPF you destroyed so its a good and bad idea at the same time if you see what I'm sayin
zolson is offline
post #8 of 12 Old 05-03-2013, 10:06 AM
I hear you, but you can pick-up a used DPF for about $250 +/-. You could get one of those for about the price of an aftermarket exhaust and keep your "Good" DPF for the what if's? Either way, good luck
post #9 of 12 Old 05-05-2013, 09:19 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I'm with turbo kidd. Either delete it or don't mess with it. Deleting is the only thing that will increase mileage.
I would pick up a clogged DPF and hollow it along with doing block off plates for the EGRs to stop the hot airflow but still look stock.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #10 of 12 Old 05-05-2013, 07:04 PM
ajordan6337's Avatar
If I were you I would leave it by sounds of things.
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
Tags
6.4 , filter back system , mpg increaser , muffler delete
