Brakes - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-02-2013, 11:51 AM Thread Starter
Brakes
Is there an upgrade on brakes for the super duty. Bigger rotors and pads. Or is there just replacement parts
ajhester is offline
post #2 of 6 Old 05-02-2013, 11:59 AM
Use the search bar. Plenty of threads on this already
Moto2four is offline
post #3 of 6 Old 05-02-2013, 02:08 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
Lots of people swear by the OEM pads and rotors from the threads I've read. When I had to get new pads, I went with Motocraft. I didn't need new rotors at the time since they could be turned down but if I did, I'd still go with OEM spec.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 6 Old 05-02-2013, 02:09 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
Yup motorcraft. Mine lasted 95k miles and I wish I would have went back with motorcraft.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 6 Old 05-06-2013, 06:13 PM
Quoted: 2 Post(s)
I did a ton of research on this as well when I thought I was going to need new pads. Based on what I read I would go back with OEM. Seems like all the guys that went aftermarket found out that they made a bunch of noise, dust and wore faster with no big improvement in performance.
713Diesel is offline
post #6 of 6 Old 05-06-2013, 06:29 PM
ATVJOE's Avatar
I too did a lot of research OEM is the only way to go, 100,000 on original
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
