6.4 max AC mod?? - Ford Powerstroke Diesel Forum
post #1 of 42 Old 05-01-2013, 09:45 AM Thread Starter
rt_hawk's Avatar
6.4 max AC mod??
Is it possible to do this? I did this with my 7.3 w/ a ranger heater core valve, does the 6.4 use vaccuum for the hvac controls? I know most of them are electronic now...Or would I need to use a electronically controlled valve to block hot coolant from the heater core when the air is on? I know I could throw a ball valve in there, but it would be great if I could set this up like in my 7.3...does anyone know a place that makes a electronically controlled valve to shut off coolant flow? Thanks in advance everyone...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #2 of 42 Old 05-01-2013, 10:02 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
What does this do? Colder air?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 42 Old 05-01-2013, 10:18 AM Thread Starter
rt_hawk's Avatar
Yup, blocks hot coolant from going through the heater core all the time, makes it easier to cool down the truck, worked awesome in my 7.3, used the vacuum controlled valve from a ranger tied into the stock hvac vac controls in that truck...the valve blocked flow when max ac was selected...
rt_hawk is offline
post #4 of 42 Old 05-02-2013, 02:50 PM
I did a similar mod to my 99 Super Duty and seem to remember reading that Ford eventually made this a production mod.
2010 F-350 6.4 CCLB FX4
4.5 carli, deleted, spartaned
1999 F-250 v-10 CCLB LARIAT(sold)
Sufbark is offline
post #5 of 42 Old 05-02-2013, 02:59 PM
6.0f250firstcar's Avatar
It doesn't do this automatically?
Ryan
6.0f250firstcar is offline
post #6 of 42 Old 05-02-2013, 03:52 PM
srjd's Avatar
Quoted: 2 Post(s)
If my ac was any colder if freeze to death
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #7 of 42 Old 05-02-2013, 05:01 PM
Powerstroke Techie
I've never been overly impressed with the air conditioning performance in my 08. I've tried playing with the charge level as well, to no real avail.
I don't like that the same size cab, which was originally (pre-08) cooled with almost 3 pounds of R134a is now only cooled with not even 1-3/4 pounds of refrigerant.
I don't even find the air sufficient in a single cab truck, 08-10.
I have often thought about putting a ball valve in the heater hose line to interrupt flow through the heater core. Most every big truck (transport, dumptruck, etc.) has a shut-off valve for the heater core for summer months.
The problem with the vacuum actuated one is, as you've stated above - the controls are all electronic now, there isn't any vacuum to the head unit in the dash anymore, and some trucks don't even have a vacuum pump!
It's getting to the point now weather wise, if you put a shut off in the heater hose you'd probably be ok without heat for a while. And worse came to worse, jump out, pop the hood and spin the valve open if you needed to.
I'm going to take some before/after measurements when I do this, but before that I also need to replace the blend door motor for the temp door.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #8 of 42 Old 05-02-2013, 06:31 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
No sh!t I agree with you man... I'm in Dallas, and in August when temps are well over 100* with high humidity, after rising around for 20 minutes I either turn the ac fan speed down to the lowest, or I up the temps because its too damn cold. And I like it cold, even in the winter I keep it on 65* after I get er warmed up.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #9 of 42 Old 05-02-2013, 06:32 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
mines a freezer...!
Big_Smokey is offline
post #10 of 42 Old 05-02-2013, 06:45 PM Thread Starter
rt_hawk's Avatar
My 08 is nothing special for AC, checked the freon, all good, so I put a ball valve in yesterday, all my tractors have them, they are ford too! Well some new holland, same deal... it was 85 the day I did it but now it's a balmy 32... ...when the summer comes I'll let everyone know how it works...I'll post a pic tomorrow...and I thought ford made the valve for the excursions?? And rangers etc...
With the temp drop I had to hop out and flip the lever back to open taking my kid to school this morning! 50+ degree drop is nuts! Ill do some measurements valve open/closed as well, just to compare results and make an average... Also I put the valve after the tee for the coolant filter, so it wouldn't stop filtering when the valve is off...
Wish I could find a electronically controlled valve, but that's probably way more trouble than its worth, but than again, I have done a lot of stuff like that (ends up costing more and takin more time) just to give it a shot, one day I'll learn...maybe??
rt_hawk is offline
