Are my -28mm offset 35x12.50's always going to rub? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-30-2013, 05:51 PM Thread Starter
Question Are my -28mm offset 35x12.50's always going to rub?
I have a set of Moto Metal 951's with the -28mm offset, and 35x12.50/18 Nitto MT's on them and they rubbed even with a 4.5in lift kit on my 05 F250. I read that a lot of people were able to mount 35's on 08-10 without a leveling kit so I tried that tonight on the front and they seemed to rub about the same amount as they did on my 05. Even though my 2010 is bone stock.
I was curious if because of the offset of these and the super wide stance if they are always going to rub at full ****? I ask because if they rubbed with a 4.5 lift kit, I am assuming a 2.5 inch leveling kit isn't going to make any difference on the 2010 I just purchased.
I am leaving this Friday for a trip with the toy hauler and am looking to beef up the stance a little instead of the stock 17's and wanted to see if anyone knew if these would always rub at full **** before I mounted them and let them go.
Thanks!
Sorry about the *** it means full turn, just a "bad" word....
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #2 of 12 Old 04-30-2013, 06:00 PM
BIG Laing's Avatar
Why did you post this twice? I hate when people post the same thing twice ****er.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 12 Old 05-01-2013, 02:45 AM Thread Starter
Haha, sorry, normally I hate it too actually, but was flipping out and in the heat of the moment made a bad decision
post #4 of 12 Old 05-01-2013, 05:24 AM
WoodBoy's Avatar
Where are they rubbing? I run the same wheels/offset with 35x12.50x20 ATZ and I dont have any rubbing, I have 2.5" up front. Only thing it rubbed was the inner fenderwell liner and you can take a knife and make a slit to slide a zip tie through to hold it back or you can cut it. I cut it the same way it was factory, just about an inch bigger so you can not even tell it has been cut
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 12 Old 05-01-2013, 06:16 AM Thread Starter
That is good news as my 2.5 leveling kit will be here and installed next weekend, so I am just running stocks right now. Are you talking about the front fender liner or the rear. Mine appear to be rubbing the rear fender liner by the nerf bar right now, but again that is not leveld. I think they were also rubbing the inner liner up front, but again, this is not with a 2.5 leveling kit yet.
I just was curious as I am racing this weekend and have to haul the toy hauler and was hoping for the heavier duty wheels/tires and wider stance. I think I may mount them up anyways and just austin powers the toy hauler out of storage, back and forth, back and forth lol.
Thank you for your help.
post #6 of 12 Old 05-01-2013, 10:01 AM
WoodBoy's Avatar
The rear fender liner.
WoodBoy is offline
post #7 of 12 Old 05-01-2013, 06:20 PM Thread Starter
Yeah, that is definitely where I saw the rubbing last night when I had the fronts on. But mine is rubbing on the bottom of the rear fender liner, like midway across the width of the wheel well. I feel like 2.5 inches will make it clear though and should know next weekend.
Thanks for your help.
post #8 of 12 Old 05-05-2013, 06:56 AM
Quoted: 47 Post(s)
Mine rubbed the liner so I cut it. Problem solved.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #9 of 12 Old 05-06-2013, 05:42 AM Thread Starter
Yep, that's the plan this weekend after leveling kit. Thanks boss. Also your truck is sick!
post #10 of 12 Old 05-09-2013, 07:57 AM
Quoted: 47 Post(s)
