overdrive ??? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-28-2013, 10:03 PM Thread Starter
spartan-alteran's Avatar
overdrive ???
hi I got a 1997 f350 im new to theses truck and I wana know watt is the overdrive ?? and wen to uses it ??
spartan-alteran is offline
post #2 of 2 Old 04-29-2013, 02:16 AM
WD40's Avatar
Quoted: 30 Post(s)
Do you have a real temperature gage on your truck and does it have new or real clean fluid in it and if you say yes to
these, just put it in O/D and drive it. If the transmission temp gets up around 200 pulling a hill back out of it a little.
If the transmission starts shifting down and then back up to O/D then turn off the O/D tell you get out of the hills.
Don't let your temp go over 200 for over 10 min.
Will you be pulling a RV or big boat? Good Luck.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
