Amsoil Change Interval - Ford Powerstroke Diesel Forum
post #1 of 20 Old 04-27-2013, 06:52 AM Thread Starter
Hey all,
I have used Amsoil for years in everything I own. I am about to do the first oil change in my 08 6.4l, 75,000 that I recently purchased. What is the drain interval recommended? Amsoil says to use the manufacturers longest drain interval which I believe is 10,000 miles. Anyone else use Amsoil? What are the drain intervals you use? Longer? Shorter? Any problems either way? Thanks a ton!
2008 F-250 Lariat
6.4L Powerstroke
smokinflame is offline
post #2 of 20 Old 04-27-2013, 07:00 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
If the truck has a DPF dont go a mile over 5k and in that case there is no point in using a synthetic oil. I use motorcraft oil and still change mine every 5k miles even though I am deleted. Cheap insurance.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 20 Old 04-27-2013, 07:46 AM Thread Starter
Thank you Strokin! I read all about the DPF and the problems it causes. What the hell is it and why do people delete it? Does that cause a lot of the ****ty gas mileage? I don't know a thing about it other than my dash says it is cleaning every now and then. Thanks for your time.
2008 F-250 Lariat
6.4L Powerstroke
post #4 of 20 Old 04-27-2013, 01:07 PM
srjd's Avatar
Quoted: 2 Post(s)
Well since you are currently not deleted amsoil is a huge waste of money. As all ready said do not go over 5k with dpf. I don't have dpf or egr and I do 4k max. Yes dpf causes the bad milage. In short. It traps the soot in the filter and burns it off when it gets full. When it burns it off it overloads with fuel and usually some of that fuel leaks down into the crank case. A quick search on the site you can find out why you should delete it. Either way if you do delete there is no magic number on OCI as every drives different and in different conditions like more cold starts or dusty conditions. So simple rule if not deleted dont go over 5k and if deleted send it to blackstone or a place of your choice to have it tested and see what works best for your truck.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 20 Old 04-28-2013, 04:13 AM
I do 5K on royal purple and I'm deleted both DPF and EGR. Even once I do CCV I will still do it at 5k. Simple insurance on an expensive motor/turbo set up. Plus I get royal purple for $9 a quart
Trouble maker is offline
post #6 of 20 Old 04-28-2013, 05:50 AM
Quoted: 725 Post(s)
Why waste your money on RP if your going to change it every 5k? Do an oil analysis ($20) and filter change at about 4k and go from there. They will recommend when the next change is and/or recommend to send in the next sample. Maybe you will be able to double your mileage and save the cost of an oil change.
FWIW, I used to run Amsoil in everything but my truck, now it is there. I sent in a sample at 2500 miles. Everything came back perfect and even a couple of numbers came back better than what the oil was spec'd at (I must have got a few good quarts). Suggested I not send another sample in for another 7000 miles. Of course I don't have a DPF or an EGR, and I know my compression numbers are really good.
Corey@CNCFAB is offline
post #7 of 20 Old 04-28-2013, 06:02 AM
Quoted: 270 Post(s)
I just do not understand why people want to do extended oil change intervals. It's like $60 and 15 minutes of your time. Just use motorcraft and change your dang oil. I wouldn't put amsoil in my lawn mower. Last time I was at the shop with my truck there was a 6.0 in there with the motor torn down and I asked what happened and the mechanic lead me over to an oil pan filled with black jelly and he said Amsoil happened.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #8 of 20 Old 04-28-2013, 06:17 AM
Quoted: 725 Post(s)
Lol. That's not from Amsoil nor any motor oil would cause that if it's changed regularly. That's called neglect and an emissions issues that causes sludge. That mechanic just wanted to use that as an easy excuse to blame something.
I've seen that with many engines, gas and diesel in all different makes and models, more so on GM gasser's.
post #9 of 20 Old 04-28-2013, 06:34 AM
superduty6.4's Avatar
I sure hope mine doesn't look like that . I've been using amsoil for 130,000kms and doing 10,000km changes since new.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #10 of 20 Old 04-28-2013, 06:38 AM
Quoted: 270 Post(s)
I get oil analysis done ever couple oil changes and use motorcraft and they said I could easily go to 8k miles but I still change at 5k. If motorcraft can do this well why would anyone pay more for oil? I just don't get it. It's just a racket.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
