Looks like blown motor, suggestions needed... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-26-2013, 08:13 AM Thread Starter
Right now you can start the truck but one cylinder shows 35% compression loss. A boroscope is about to go take a look...
Just curious, if I do in fact have blown motor on a 2008 F-350 KR, which route would you take?
Get a crate from Ford to have the 2 year/unlimited warranty?
Rebuild my current block and add "x" parts?
I have a third party warranty but was told that if it was an injector that caused it it would not be covered. If it is a piston, what else could cause it if not an injector?
A little history from another post I started 2-3 weeks ago...
"(2008 F350 KR) I was driving to work this morning and I started feeling some vibration like I had a flat. I pulled over to check and noticed a puff of smoke from the tail pipe. Tires looked fine so I got back in the car and noticed a definite misfire.
When I left this morning I thought the truck sounded just a tad rough but it drove fine while I dropped off the kids. I then filled up (could be bad diesel?) and set out on my 42 mile trip to work. About 8 miles into it is when the truck started shaking.
I do not have any check any lights and there was no overheating but there is definitely some kind of misfire going on.
I just put a scanner on it and I'm getting a P0302, Cylinder 2 misfire."
Cajundude is offline
post #2 of 16 Old 04-26-2013, 10:44 AM
Well that's your problem you put gas in it ahah
Sent from AutoGuide.com App
2008 F250 XLT 4X4
H&S Mini Maxx
S&B CAI
5" Turbo Back Diamond Eye Exhaust
Sinister EGR Delete
CCV Mod
Fabtech Dual Steering Stabilizer
6" Pro Comp Lift
37x13.5-20 Toyo Open Country MT
20" Dick Cepek DC-2 Rims
bag711 is offline
post #3 of 16 Old 04-26-2013, 10:53 AM Thread Starter
Lol Fixed...
post #4 of 16 Old 04-26-2013, 12:42 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
It seems like it usually is an injector that causes a piston to go bad. Usually from overfueling. Why will they not cover it if its an injector that caused the piston to crack?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 16 Old 04-26-2013, 06:08 PM Thread Starter
Because it is a slimy aftermarket warranty company. I am in the automotive industry and I deal with them all the time. They suck, all of them.
I am not however in the diesel business which is why I purchased this warranty. Sometimes it takes a little fighting so I am going to pay for it and then go after them to collect. I think I am probably going to go the Ford crate route, then everything will be new, motor turbos, injectors, etc...
post #6 of 16 Old 04-26-2013, 07:06 PM
BlackSheep5's Avatar
I just got a 6.4 from Ford a couple months ago. Complete engine cost $12k and had to take it back after 40 miles, miss on #8, turned out to be a faulty injector harness under the valve cover.
08 F250 6.4L FX4
BlackSheep5 is offline
post #7 of 16 Old 04-26-2013, 07:52 PM Thread Starter
Well that is just lovely. I take it there was no hassle? You get the 2 year unlimited mileage warranty with it right?
post #8 of 16 Old 04-27-2013, 06:13 AM
ckehl2's Avatar
A few years back I had this same problem with a 2001 Duramax LB7. Failed injector caused a piston to crack. I too had an aftermarket warranty. It took about 4 months of being without my truck, but they eventually replaced the motor. The main reason I switched to a power stroke. :-)
2008 F-250 Crew Cab 4x4 6.4
SCT Livewire w/Gearhead Tuning, 4" MBRP Exhaust & S&B CAI
ckehl2 is offline
post #9 of 16 Old 04-27-2013, 06:23 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
I had my #8 injector hang open and I cracked the 8th piston clean in half and drove at highway speeds like that for 2 hours. Tore it down put a new piston, rod, and injector in it and kept kicking. There was no damage to the cylinder wall.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #10 of 16 Old 04-27-2013, 06:49 AM
at0075's Avatar
12000$$ holy Moses. Think about what you could do to your block for 12,000 if it was ok. Injectors, turbo, tune, Chrome, and more chrome!!! Haha that my look on it. That is if you had the abilities to pull the motor yourself. Even if you didn't and payed someone I don't see it being 12000
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
