How to remove rear hub on 2008 F250? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-25-2013, 06:34 AM Thread Starter
justindacey's Avatar
Hey guys, I had to replace the rear rotors and brake pads the other day on my Superduty. When I pulled the rotor off, I noticed the emergency drum brake shoes on the passenger side were almost falling off. The plate that holds them into place is completely rusted. I purchased a new one from Ford but I'm unsure on how to remove the rear hub to replace this part. Any help is greatly appreciated.
justindacey is offline
post #2 of 2 Old 04-25-2013, 09:52 PM
44magnum's Avatar
Quoted: 2 Post(s)
To get the hub off you have to pull the axle shaft which is only 8 bolts then to get the hub off the axle tube you need a special socket you can get it at any auto parts store.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
