6.4 bad turbo - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-20-2013, 03:29 PM Thread Starter
6.4 bad turbo
So me and a buddy was tearing my truck apart the other night to replace the head gaskets and put arp studs in it, and when we took the intercooler off, oil started pouring out, we came to find that the seals were bad on a turbo and one turbo has shaft play in it.
So I'm needing some answers, As of right now the gaskets and studs sit me back and I don't have the money to drop for new turbos and this is my daily driver.. Is there somewhere I could just buy a rebuild kit for it?? Ive seen the new compressor wheels, would putting them in fit my shaft play??
Im needing any help. Thanks
2008 F-350 CCLB SRW
Job 3
H&S mini maxx
Sinister EGR delete
Soon to come: 4" exhaust, leveling kit, 33/12.5/17's, chrome grill and bumper, xlt headlights, and S&B cold air intake.
Cah430 is offline
post #2 of 8 Old 04-20-2013, 06:15 PM
TD-5's Avatar
Quoted: 3 Post(s)
I suspect the oil in your intake tract is from your crankcase ventilation system. Oil in the intake tract is common.
TD-5 is offline
post #3 of 8 Old 04-20-2013, 10:52 PM
srjd's Avatar
Quoted: 2 Post(s)
Are you sure the seals are shot? Like he said could be from CCV
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 8 Old 04-21-2013, 05:33 AM
ramonpowerstroker's Avatar
Oil inside the intake is from the CCV, this is normal, if you have shaft play then I believe a blown turbo is in your future
ramonpowerstroker is offline
post #5 of 8 Old 04-21-2013, 06:25 AM Thread Starter
I'm pretty sure it's the seals on my high turbo, it wasn't just a small amount of oil, I'm talking close to two gallons of oil, it was a state truck before I bought it, and looks like it has had the cab off before. So no telling what all they have had trouble with
2008 F-350 CCLB SRW
Job 3
H&S mini maxx
Sinister EGR delete
Cah430 is offline
post #6 of 8 Old 04-21-2013, 07:03 AM
dt23400's Avatar
get oasis report from ford.theyre free
2005 rclb 6.0 f250
372k 4inch exhaust sct x4 stock tunes 54 ficm
2002 gtp precision t62 turbo zzp turbo cam zzp tranny 65lbs injectors 505whp 25psi
2006 sti stage 2
dt23400 is offline
post #7 of 8 Old 04-23-2013, 06:20 AM
Oasis report, and does the turbo have shaft play?
post #8 of 8 Old 04-23-2013, 06:21 AM Thread Starter
Yes the turbo has some shaft play, side to side and front to back a little
2008 F-350 CCLB SRW
Job 3
H&S mini maxx
Sinister EGR delete
Cah430 is offline
Tags
6.4 , turbos
